D&H Rocky Mountain Empire (N-Scale) - Design Stage
OK, I’m starting to get serious in designing my future N Scale layout but need a few pointers. The MOH and I still need to work out some ROW limits but basically I’m heading into a basement bedroom and maybe an extension into the family room that will either be just the Double-Helix or Double-Helix & City/Yard area between the Helix and Bedroom.
So, I have a few upfront questions that will likely lead to more questions. My initial question is Minimum Radii given my roster of equipment I’ve been collecting over the years (Click Here) as I will want to go as tight as I can. My main area of concern would be my passenger consists (Adirondack Consist #1, Laurentian Consist #1,and Montreal Limited Consist #1) which would likely be pulled by multiple 6-Axle PA’s.
I’m looking at a Loop Style “DC” layout that is a walk-around using two of the physical walls leaving the other two open as aisles. I will also plan to go vertical with either 2 or 3 levels. Track #1 / #2 would be on Level #1, Track #3 / #4 on Level #2. Would like to have a Double Slip switch setup so a trains can either us each track separately or have a single train use the Double Slip to use both tracks as one. The Inner Helix would be for downward travel from Level #2 to Level#1 and the Outer Helix for Upward travel.
So what would be your recommended minimum Curve Radii, and Turnout #. I’ve been messing around in CAD using 13.75", 15.00" , 16.25" and 17.00" curves and #5 and #7 turnouts to try different designs but now I need to know what is reality for my roster.
Also feel free to a
Curve radius rules-of-thumb from the Layout Design SIG
Based on the statement from one of those links “This measurement is based on the length of your longest car (coupler to coupler)”, does that apply to both Body Mounted and Truck Mounted couplers?
Generally speaking, yes, IMHO. Truck-mounts might lower the radius requirements slightly. But if any of your long cars will be body mount, that’s the worst case for which you should plan.
Current ROW Limits
Here is the current ROW limits being discussed (in yellow) and “I hope” to expand over to the window on the far right passing the bench-work “over” the desk. So the Helix right now would be to the left of the Fireplace (38"x38") and the track would pass through the wall onto the main layout area in the “Train Room”. We don’t use the Fireplace so having the bench-work pass over/near it’s opening is not a concern. The “Train Room” has two small windows that are up near the ceiling as the basement is underground and the room is already Heated/Cooled year around. If I can get the additional ROW it would be gaining a 38" deep bench-work all the way over to the window on the right and I would move the Helix over to the far right next to that window. So, basically I have a solid 8ft x 9ft zone to work with plus the 3ft x 3ft behind the door as well as a 3ft x 3ft area outside the room for the Helix that would have easy access to it and doesn’t need to be hidden by scenery given it’s location.
[#welcome] Welcome to the Forums.
Design Concepts being played with
Visualize a Grid Label system for the squares as “A” through “N” across the top and “1” through “9” down the side.
I’m thinking about using a 9-12" deep bench-work from A1 to H1 where it would have 4 tracks. Two of them would be Track #1/#2 for Left-Bound and two of them would be for Track #1/#2 Right-bound. Either the Left-Bound or the Right-Bound would be at the same elevation for the one and only Cross-Over for the level. The other direction for Track #1 / #2 would have a ~3" difference in elevation with Track #1 potentially “hidden” under Track #2 so only three of the 4 tracks would be visible. Access to the hidden track would be a simple reach under the bench-work.
The 3x3 Area of I1 through K3 would be for a 180+ degree turn of Track #1/#2 as well as allow the Inner Helix to enter onto Track #1 (downward path) and for Track #2 to exit into the Outer Helix (upward). The Inner-Helix would make one more rotation to give me a 2+ inch clearance to go under the Outer-Helix and thus give elevation difference for Track #1 and Track #2 to use the same space.
Continuing this thought using a 9-12" deep bench-work from A1 to A8 would also have 4 tracks; likely the same part of Track #1 being hidden and potential one direction of Track #2 also being in a “Tunnel” it entered in A1. At “A8” the four tracks separate onto the main bench-work in the middle of the room.
I’m thinking having a View Block between A8 / A9 through F8 / F9 so viewing from the “Shelf” Area one would see two tracks exit tunnels at different elevations around B9 / A9 and head along a 9-12" depth using Row#9 of the grid. Both tracks would eventually turn upward onto the main bench-work in the middle of the room…
Using B2 through C7 as
HELIX / Level #1
OK, based on comments I get earlier from various forums, right now I thinking about a Double Helix at 16.25" / 15.00". Remember I’m thinking DC thus the Inner Helix would be Downward traffic only and the Outer for Upward traffic. I’m thinking Level #1 for a 2-Track design that will use a Double-Slip allowing a single train to travel over both tracks to double the length of the loop of two trains traveling each track separately. Track #1 would be lower then Track #2 except where they meet at the Cross-Over. Looks like I will need to go no lower then a 15" curve, use #7 turnouts w/ a 71" curve for side track switching and user #10 Turnouts with 11.25 crossing for the Double-slip design.
I’m not hard set on the heavy track design but trying to see if the space can support the concept
With that here is a potential design showing a Double-Helix and the Side Track; one that would attach to Track#1 (Inbound) and the other to attach to Track #2 (Outbound)
As I have N scale I have to say that the largest possible is what you go for. You have been reading these forums for a long time (and N-scale forums at least some) so an 11" or more in yards and industrial switching areas is a must. On mains then 15" plus. Unless you are running only 6 axle diesel engines or long steamers (which I believe you are doing) then even larger if you can. Of course any long passenger cars or long flat cars look better on wider curves.
Looking at the picture you have linked to it seems you have some 50’ rolling stock. I also have some longer cars…
Most likely you will do as many have and redo parts of the track when you find out it is not what it needs to be. I have some sections that I had to use 11" to make it fit. All engines and rolling stock do fine, just more over hang the I would like. Though I am more concerned with operations then perfect looks.
I hope this makes sense. Oh, and have fun![:D]
Darren, I did not know you did N scale until this post. Since nothing in your post (at least that I read) or your end tag said N scale I always assumed it was HO.
If I see some one saying “blog” I almost never bother to click on it. I have read about other modelers saying the same. The feeling being it is just the same as their forum post.
You need to add that you modeling is in N scale. Or is it you are ashamed of doing N scale?[;)]
LOL!!!
My D&H RR Model collection is just under 650 pieces of various scales. I think folks just got use to my HO Space dilemma and they have just assume I was purely HO but the collection covers many scales.
Currently the Scale break out is:
  • G - 1
  • O - 39
  • S - 1
  • OO - 1
  • HO - 388
  • N - 210
  • Z - 4
[(-D]
Track #1 from the Helix
Here is a potential beginning of Track #1 that I have been playing with and also a placement of the Double-Slip switch to get back-n-forth to Track #2. About 50% of what you see of Track #1 would be hidden that I will show later and nearly all the track behind the entrance door from the Family Room wouldbe hidden so the door being open would just be part of the View Block; at least that is where my head is at currently…
Track #2 to the Helix
Here is my potential beginnings for Track #2 and how it would hook up with the Double-Slip. Track #2 would be on the same Level as Track #1 but higher except were they meet at the Double-Slip. About 50% of this portion of Track #2 would be hidden (will show later) but mainly the track behind the door as it enters a tunnel making the 180 degree turn and the section of Track #2 that passed under itself is what is hidden.
West/Top Wall - Level #1
OK, here are a couple of diagrams show both Track #1 (GREEN) and Track #2 (BLUE). This first shows all the track in this section and the second is how I think the hidden track might look. Note the Helix is just an option to get between levels and thus Track #1 and Track #2 would turn behind the door to allow a train to stay on this level. If it’s better to have the Outer Helix be the downward and the Inner be the Upward I might have to adjust things a bit but that is exactly the advise I am looking for!!!
I’ve zoomed in a bit so it’s easier to see what tracks are at what elevation with respect to each other. In this first view you can see the four tracks heading down the left wall but the two closest to the wall will be hidden. Allot of the Top wall will also be hidden so the “Track Heavy” look in this view should lighten up in the next diagram…
Here is the Hidden Track view of above. There is track at three (3) elevations with Track #1 (GREEN) being the lowest near the edge of the benchwork. About 2.5" above that is the Double-Slip where Track #1(Green) and Track #2 (Blue) can be combined for a single train to use both tracks as a larger loop within this level. Finally Track #2 (Blue) closest to the wall is higher yet and the most visible in this section. The “Access” hole would be 100% behind a View Block / Scenery and a panel behind the door could also be removed for access too. After that, access to remaining hidden track would be from below
Have you considered first creating an operational schematic? Generally, this step comes before the actual track plan and determines “why” tracks go where they are going.
Here is an example from another MR forum member:
http://cs.trains.com/TRCCS/forums/t/129072.aspx
Track #1 / #2 - Box Canyon
OK, here is as far as I have put any serious thought into the Level #1 and hopefully these next two diagrams show the concept I am hoping for down the dead-end aisle. Track #1 (GREEN) and Track #2 (BLUE) head Up/Down the South Wall. Track #2 reaches the end of the Box Canyon and then makes a 180 turn back up the other side while Track #1 pass into a tunnel; that might represent the look along the Moffat Route where a trestle passes over a tunnel.
!(http://www.ghostdepot.com/rg/images/moffat route/moffat looping loop trestle tunnel pc.jpg)
At this point the 4 tracks (2 Hidden) along the South wall separate with two appearing on the far side of the View Block and two travel back up the edge of the Box Canyon. Note the hidden portion of Track #1 from the South wall is the track that appears on the opposite side of the Canyon and the hidden potion of Track #2 from the South wall is the track that appears on the opposite side of the View Block.
Here is how it might look with the Hidden Tracks not showing…
Does this help explain my current thoughts for the South Wall
hi Darren,
i have been going a step ahead.
a few remarks.
  • the helix area does triple duty, a small part is used as a return track for the upper oval, while the space under the helix is used for staging or a passing siding of the lower oval.
  • I made a very long mainline run possible. Going down from the helix you make a lap on the upper oval first. Using the double cross-over (Highcross-Basecross) you can enter the lower oval; after a lap on it you could reverse the direction of your train in the yard or by using the reversing connection. Then you could head back to the helix and eventually a second floor.
  • Because the helix has dedicated up and down tracks the plan can be operated in loop to loop fashion. So the cross-over in the helix area does double duty too.
  • On both ovals some passing sidings are added. Some old tricks would be great to work in. Like two trains on one oval, in different directions passing each other. All done automatically using a computer or relay’s.
*By having the return loops in the helix area the “loops” on the peninsula can be made 2 ft longer.
*I did not pay much attention to scenery…it was more about creating independent ovals that can be used as one very long main as well.
Paul
Stuck
OK, before I step back to take a serious look at what folks have offered as suggestions on various forums, this is the point I’m a bit stuck…
One item for a Multi-Level layout, what is the best way to support the Upper Desk(s) while wanting to maintain a L-Girder design throughout. What I would like to avoid is having any outside supports that blocks the view of the mainline so how does one support Level #2+ from within. I assume I will need some support posts in the middle that will need to be considered in the design plus I plan to pull in the electrical for lighting from the ceiling light which is basically dead center in the room…
Question
Paul, I can not THANK YOU enough for putting in the time on these diagrams as they truly are helping me understand the possibilities of the space while achieving the goals I am looking for. Don’t worry about the scenery as I can adjust that later to be more Rocky Mountain rouged like and I can toss in a tunnel here or there to fir into that landscape vision as well.
Questions:
  • How would one support another level above this with highly similar bench-work, would there be sturdy support poles within the View Block that I could hand L-Girders off of every 16" or so?
  • Can you either post a zoomed diagram of the Helix area that I can see if I see how sectional track would be connected to achieve that design? If it’s easier to just email me a larger JPG file of the whole diagram that would be great too.
  • There are folks that have suggested the Outer Helix should be used for Down where I thought it would be better for upward travel. What are your thoughts on directions?
Hi Darren,
here is the detailed helix you were asking for.
*One remark however, if you look carefully you will see that the spacing due to the crossover is not correct. You will have to trim the left-hand turnout a little bit.
  • IMHO the most sensible action is to buy a book about multi-deck layouts by Tony Koester.
  • Since going down is often causing the most of the problems in a helix, you could use the outer track for downwards moves. The difference in grade is very small, only when you are running long trains or trains with light and heavy cars i do not think you will encounter much problems due to the choice of direction. However:…
with the 15" radius the grade will be 3,1%, adjusted for the curves the drag will be comparable to a 4,2% grade; pretty steep indeed. The radius in the helix could become the difference between a working or a not working design. To find out you could set up an experiment or ask Byron Henderson about this issue. I do not have first hand experience with this radius/helix combination.
Smile
Paul
