I don’t think foam will stick well to plastic grass matting…
Jeff, have you ever heard of or tried out the Weld Bond glue? It is a white glue that sticks to just about anything, including plastic. I use it everywhere on my layout…
Yes, I have tried it. There are things it doesn’t stick to well. Here’s the list.
Some plastics, rubber and cast metals won’t produce a bond including polyethylene, unbacked vinyl, PVC, Teflon, polypropylene, vinyl to vinyl, cast iron, cast aluminium and “pot” metals. Do not use it when bonding containers designed for use with hot liquids. It must be stored at a temperature above 50 F and below 93 F. If it freezes while in a liquid state it will separate into it’s component chemicals and becomes unusable. Not nit-picking, that’s just my personal experience with it. Aside from that, it works pretty well.
