I have a need to glue some Woodland Scenics retaining walls onto plaster cloth. Does anyone know if DAP caulk would work on top of plaster cloth to attach these, or what is recommended? Thanks!
Caulk should work just fine for this application. A mixture of thick plaster would, too.
I use adhesive caulk to attach various scenery items to plaster all the time. The DAP acrylic/latex sealant should have sufficient holding power to work as well. I’ve had better luck with caulk than plaster for attaching such things.
Thanks all!
Along these same lines, does Sculptamold and/or Smooth-It work on top of plaster cloth as well?
Sure. If it sticks to any other typical scenery substrate material, it will normally work on plaster cloth.
