Since there have been some questions about running DC only locos with a DCC controller capable of running DC only locos, Yes, it is kind of technical. I had no way to measure the mechanical vibrations which will eventually affect a motor.
I did some temperature measurements as an experiment. The applied DCC signal is 30 volt pulses at a frequency of about 6khz.
Remember, the motor signal is the same as the track signal.
I recently used a MRC 2000 DCC controller that can run DC only locos to look at motor temperatures. The first was using a small can motor used in my HO scale 4-4-0 locos. The motor temp was 68F at the start. With zero throttle, the temp went up to 92 F after ten minutes.
At one third throttle, the temp went to 105F after five minutes.
Back to zero throttle, the temp dropped to about 96 F after five minutes.
I then did the experiment with a open frame motor from a older MDC box cab.
At zero throttle, the temp went to 85F after five minutes.
At one third throttle after five minutes, the temp went to 104F.
After five minutes at zero throttle, the temp was 95F.
In both cases, the motor is in open air with only a flywheel for a load. You could say these are ideal conditions.
With the motor enclosed and sometimes run near max throttle and pulling a load, a lot more heat can develop.
