DC power pack evaluation
Hello every body,
My current layout is run on DC and it uses a variety of power packs. Due to the variety of power packs, the differences in performance and reactions from the locomotives, I thought that there might be interest in the experiences gained. Also there seem to occasionally be questions about power packs and hope that this is of help.
My oldest power pack is a Life Like Model 2952. It is a small steel box with a toggle switch for forward and reverse and a throttle that reads in MPH. Capacity is 10 VA, Probably made in the 80’s.
This unit is used for cleaning the wheels of the locotives, basically there is a thin rag over the tracks with alcohol in the rag and I hold onto the locomotive as it runs with one set of axles on the rag, the other set of axles on the track. The power pack serves very well for this purpose and has enough power to get the job done. It has very limited power and speed control is dismal.
In my Presidents Choice trainset there was a power pack. It came with a wall transformer that has a output of 8 VA.
Enough to run a locomotive by itself, control of the locomotive is good, in the sense that one can start slowly and the motor does not growl. It has limited walk around capability but is trainset quality and does not have enough power to run mainline HO trains.
The MRC 220 power pack was purchased new from a hobby store. It is a Tech 4 with a ON/OFF button, Direction button, Momentum button and a brake button. It is rated at 17 VA.
This power pack can make my locomotives Crawl. The speed control is great and the motors from the locomotives are quiet. No growling or humming that is readily noticeable. This power pack has been used over the years to also power the main line on my layouts with freights that were double or triple headed without a issue. Overall I am qu
I wish I had stock in the MRC corporation. Seems that you have single handedly kept them in business. I used MRC when I was powering my DC layout. They were reliable and worked like a charm. How big is your layout? You must have more blocks on your layout than Carter has liver pills. Have fun. Remember, life is not a dress rehearsal, you must reach for the dream now.
How many blocks? 14 blocks and in these blocks there are 18 switchable track sections. This is in a room that is 9 by 11 feet, has a 30 inch radius helix that connects three levels and a loop that goes below for staging. Waiting for it to get warmer out so I can make up more trees. Once the scenery is complete, who knows what will be done next. Might even expand.
As for the MRC products, you are right they make a great product. Have thought of going to DCC but being a lone operator and not being too keen on sound I find that DC suits my needs quite well.
Take care
Frank
