DC sound locomotives
Im am in between getting a Broadway limited blueline loco, or a Athearn genesis SD45-2 or mp15ac, Athearn is also coming out with an sd60m/I, which is better?
Well, i model the late 1990’s in western PA, I use mostly conrail locomotives
Depends on what you’re modelling. Start with which locomotive suits your layout/era best and go from there. The blueline stuff I have works great but is a pain to convert to full DCC because of programing glitches (still can’t get mine off address 3). The others are good depending on your needs for accuracy versus good running but if you’re going to end up with full sound and dcc you’re better of in my opinion getting one already set up. J.R.
