I got this from Jim by e-mail. As is my custom, I will answer it here.
Hi Bob
I an earlier post you mentioned a Radio Shack pice to change the AC to DC. This
is my situation, I have a DC trolley and would like a small easy way to change
the AC to DC to operate the trolley with out getting out the #15 Rectiformer.
Could you please give me some instructions and parts list to make it.
Thanks
Jim Sturgeon(Phish)
Jim, I think that all you will need is a bridge rectifier and a DPDT switch for reversing. This 4-ampere 50-volt rectifier should be fine for a trolley:
You could go with a higher current rating to increase the safety margin. A higher voltage rating is harmless, but won’t give you any benefit. Here is one suitable switch:
Here are the switch terminals:
1 2 3
4 5 6
Connect the rectifier’s ~ terminals to the transformer. Connect 1 to 6 and to the rectifier’s + terminal. Connect 3 to 4 and to the rectifier’s - terminal. Then connect 2 and 5 to the rails. (I assume we’re talking American Flyer.)
