DC yard wiring
If my entire yard is going to be one DC block, do I need insulating connectors between each spur and the ladder, or can I just wire each spur + and - and the ladder source + and - all connected as one block when attached to a block selector? Thanks for any help on this. Jim
What turnouts are you using? THat can make a difference in how you have to wire it, but in the end it can be all one block, if you have no desire to park a loco on one of the tracks.
The switches are live frog older Shinohara and I don’t intend to have but one locomotive on the yard at a time.
I would recommend a couple of on/off switches on a couple of tracks. You never kinow when you will need to park one engine when running another. :slight_smile:
As Roger points out, it’s easier to do now, the later. Switches on ebay are dirt cheap.
Thanks for the replies, but I am not really asking if I should have more than one block. What I am asking is assuming my yard is all one block, then can all the track and ladder switches be connected with conductive connectors and each spur wired + and - as well as the ladder source wired + and -? Is there any conflict electrically in what I have said? Thanks, Jim
At a minimum you would need one “gap” or insulated joint on each piece of rail that bridges frog-to-frog AND all the electrical feeders must be from the point side of the turnout.
Basic rules of power-routing turnouts. Any frog-to-frog rail must be gapped, no matter how far apart they are and any feeders (unless switched by auxiliary contacts) must be at the point end of turnouts.
http://mrr.trains.com/how-to/dcc-electrical/2010/01/how-to-wire-power-routing-model-train-turnouts
This holds true for DC or DCC wiring.
My entire layout was originally built using Shinohara “old-style” power-routing turnouts. It was a learning experience.
Hope that helps, Ed
