I know this has likely been covered sometime in the past, but I can’t find enough answers, so I apologize in advance for asking for help. I’m new to DCC, no system yet and am ready to lay the bus wires. Yes, I have read wiring for DCC and numerous other sites wonderful information and either the following wasn’t there or I just didn’t comprehend it.
In all of the following, I am using 12 gauge solid wire.
I have seen various recommendations in numerous user group e-mails to limit bus line voltage drops to 5%. That’s where my questions lie.
Most formulas available deal with twisted pairs (which is what a bus uses), but all the recommedations I’ve seen don’t say twisted pair. There IS a difference in results. Is the 5% for a single length of distance of 1 wire or or is it for a twisted pair for the same length?
What’s magical about 5%? After all, on a 100 foot run of 12 gauge wire, the difference between a 5% (.7125V) and 6% (.855) drop is < .2 volts! Seems quite negligible to me. Is 10% (1.425) all that bad?
Don’t your rail and track feeds matter? If I’m running track feeds every 3 foot section of track, don’t they and the rail also carry that potential 5 amp current and share in increasing/decreasing voltage drops?
Do I really need 3 boosters (command +2) for a 120 foot run? Formulas say the run can only be 45 feet each to get a .7155 voltage, just a bit above the .7125 allowed.
So, if correct in #4, does this mean a rule of thumb is to purchase and use a booster for every 45 feet of bus run? If so, that can get prohibitively expensive…
Am I correct in assuming each booster needs its own block and you can’t just connect a booster to an existing cable run without isolating it?
If I have a 5 amp system but never plan on using more than 3 1/2 or 4 amps max, can I use those currents for using the formulas? Or does it have to be based on the max capability of the
