i always new it was possible but was never sure how it was done, does anyone out there control there DCC system using there PC . and was wondering how it was done i know it ahs something to do with dcc pc interface but wasnt sure how it was all connected and worked.
Conrail92
I run JMRI, http://jmri.sourceforge.net/, on my computer to program my locomotives. I have a Lenz L101 computer interface that I connect between my Roco system and my computer, though some DCC systems do not need any interface devices, just a cable.
It is possible to control trains through the computer, but I use my throttles most of the time. There are some who can run layouts autmatically, but I’m not one of them.
Gary
DCC manufacturers all have different ways to communicate with PCs, but the basics are the same. I use Digitrax’s Chief and their MS100 PC-to-LocoNet (Digitrax’s communications network) adapter. An application called WinLok gives me virtual throttles, and the ability to create an on-screen CTC-style panel to control turnouts, check block occupation, create routes, etc.
I too have a “Super Chief” and Winlok. I mostly use my old laptop for the virtual throttle and switch control. Looking forward to Digitrax coming out with their new comm adapter. Works as an interface for the computer as well as a vehicle for downloading too their new sound decoders. The good thing is you don’t need a fast/fancy computer. My older laptop I use is old and slow but works fine. You can also download free software for programming decoders.
Terry[8D]
Someone on the DIgitrax list pointed out the web links I was trying to find the other day.
http://www.thetrainshow.com/screening_room2.htm
click on the links to the Mckinley RR in the UK. It shows an amazing example of what can be done with a PC/DCC interface.
i own a MRC prodigy express do they sale an adapter? and after i would buy the adapter is there anything else i would need to buy?
I do not beleive that MRC offers a PC interface. You might try and check with them to see if one is coming out in the future.
Let’s say for arguments sake that they had one, your needs regarding other bits, will rather depend on what you want to do.
The first thing would be to identify the software that meets your needs. For example, I can run a loco using the JMRI software by using the PC as a throttle. I have full manual control over the system.
If I wanted to fully automate with signalling and detection of locomotives like in the UK video link above, I would need a whole lot more hardware to drive the signals etc.
I use a computer with my layout primarily to program the decoders.
However I also use the computer (laptop) as multiple cabs.
My DCC is Lenz 100 with both the 90 & 100 cabs. I prefer the 100 with push buttons over the 90’s knob.
It is very easy to control the loco’s using the computer as additional cabs.
i just want to have regular control im not planning to control any signaling, loco detection. and i wasnt planing to do this until my layoout is finished. I got to put my money into scenery and stuff at moment, i was just wondering how it was done.
In that case, a PC interface. An inexpensive used PC and the Free JMRI software would be fine. JMRI includes Decoderpro and has the ability to create multiple custom throttles.
kool i found out digitrax sales a PC interface cord will that be comptaible too a Prodigy Express system?
Conrail92,
Where did you hear that Digitrax sells a pc interface cable that will work with the MRC system? I only found this:
http://www.digitrax.com/prd_compint_ms100.php
and it says it can be used for “Monitoring”. It doesn’t say controlling. Please let me know if you found some different info.
Thanks,
Bobby
Winloc in effect runs loconet – tat is it is seen as another set of throttles (cabs) by the digitrax system. (I am pretty sure that LENZ works in a similar manner. The problem with MRC here is that the MRC communication system (LAN) is not the same as Digitrax. I am not certain if there is an MRC compatible interface. The folks to check with would be MRC.
The Museum I work with uses an older version of Winloc which allows me to tag into loconet with a throttle and run my own rolling stock and engines. Just finishe dwith 8 hours of operations for the train show. The Digitrax exhibit of locomotive detection and control was really cool.
thnx for all your info ill haft to look more into it and maybe contact MRC
when i was looking into which DCC system to buy about a year ago i emailed MRC to ask if they were coming out with a computer interface and the answer was no , and they weren’t planning to either . that may have changed in the last year , but i suspect adding a computer interface to a system that was not designed for one may not be possible . that’s the reason i bought the digitrax zephyr
note : the digitrax block detection and signalling system can run on it’s own loconet network and doesn’t need to be connected to the dcc system that runs the trains , but you wouldn’t be able to program decoders with the computer or use the computer as a throttle
Where is a good place to mail/email order the Digitrax Zephyr?
Who should I stay away from?
go to digitrax themselves and email them if thats what ur talkin about
You can’t go wrong with Bruce at www.litchfieldstation.com great service and decent pricing. He stands behind his products.
Thanks. Your not the first who’s suggested Litchfield Station. I’ll give them a try.
Bobby
Are all the DCC computer control devices linked to the COM or RS-232 ports? Modern laptops don’t even have those anymore and table PCs are beginning to let them go as well.
