Well friends, thankyou for Your answers, but I think I have to express me more clear. I installed a decoder from a Roco loco in an Athearn GP 38 and gave it address no.1. Four other locos vas on powered track with the addresses 5-10-20 and21. When the GP 38 was in use it suddently began to run eratic and when that happened 21 or 20 startet uncontrolable.Has anyone an answer to that problem. Way back when the CT 16 was high tech You had crosstalk, but I never heard the same could happen to DCC, but if so why only no.21 and 20? The GP 38 was ofcourse programmed on a special programming track.
If the loco is an older Blue Box version and the motor hasn’t been isolated from the frame, it will cause all kinds of havoc with the DCC system. Gee, how would I know that.
What kind of DCC system do you have? I have a Lenz, and the low numbers (0, 1, 2) are generally reserved for the base station and the hand-helds, which have addresses just like locomotives do.
The normal practice is to use the engine cab number as the address. One exception is the Bachmann EZ-Command, which only addresses 1-10.
