can I use a TCS DP5 mobile decoder with a Digitrax Zephyr Xtra
[#welcome]yes you can.
That’s the advantage of the NMRA DCC Standards and Recommended Practices – practically every brand of decoder is compatible with every brand of DCC system as far as the basic functions are concerned.
Thank you for the response. Now will I have to isolate the brushes on my E-7 this will go in?
Thank you. Now when I put this in a Life-Like Proto E-7 loco, will I need to isolate the brushes? On my Gp-9 I had to do this with a digitrax decoder
This should help you if they are HO scale. http://www.tcsdcc.com/public_html/Customer_Content/Installation_Pictures/HO_Scale/Life_Like/Proto_2000_E7/Proto_2000_E7.html
Pete
Thank you. This really helps.
