DCC lighing help please.
ok, so for my geesis SD60I i got the lights to alternatley flash. i ahve the lightbulbs split up, one lead on each lightbulb is going to the board, and the others are going to the green and purple wires. and I tested them YAY they worked!@, i pressed F0 and POOF theyre dead. i am using 1.5V 1.2mm bulbs. does i need resistors? [acronym expression removed] i have to buy some bulbs tommorrow, so ill try again then. all i want to know is how to make that NOT explode.
Some additional information would be very helpful. What decoder are you using would be the palce to start ?
You need to use resistors for 1.5 volt bulbs. What bulbs are you getting to replace the blown ones? Stock Athearn ones? Or you could use a decoder that has resistors already in place - the TCS A6X has a 1.5 volt output for all functions, the Digitrax DH165A0 only has limiters on the front and rear lights, not the extra functions for the ditch lights. For 30ma 1.5 volt bulbs you’ll want a 470 ohm resistor in series with each lamp for any function output that is not already limited.
I did the 470, and it dosent even light up. athearn is sending me new one, 4 of them. i bought the miniatronics 30MAones, i need 12-16MA (milli-amps)
Let’s ask again but a little louder. WHAT DECODER ARE YOU USING?
When your bulbs went POOF the decoder’s function outputs may have also gone POOF if you didn’t have a resistor in line with each bulb. You put too much amperage through the bulbs and also through the decoder.
I always go with a higher resistance value than what Ohms law calculations call for or what the decoder manufacturer recommends, for the simple reason that the initial inrush current when a cold bulb filament is turned on can exceed the recommended value.
Like Silver Pilot said what decoder are you using? If it’s the drop in Tsunami no resistor is needed since it’s set up to be a drop in and drive the 1.5v bulbs. If not you’ll need a dropping resistor on each bulb.
