DCC main buss wiring
I recently purchased a DCC system. I will run main buss wires under my layout. What is the beast method for securing the drop wires to the main busses?
A suitcase clip, trying to strip the main buss wire or a terminal every so many feet.
Read about it here:
http://www.trains.com/community/forum/topic.asp?page=1&TOPIC_ID=36389
this might also help…
www.wiringfordcc.com
Suitcase, strip and wire wrap or strip and solder.
Do not break the bus wire every few feet.
You can also use uninsulate wire for your bus, spacing the conductors a few inches apart, which make for easy soldering.
Strip and solder every few feet. I’ve heard of folks useing round screw eyelets to secure the buss wire to the underside of the layout.
