DCC On and Off
Help!! I am old and forgetful!! I am working with the Digitrax system. I have the power and track turned on. BUT, last time I ran the locomotives, I “turned them off” before I powered down the layout. I have forgotten the command to “turn the locomotive back ON”!![:^)]
Check the manuals for the Digitrax system and decoders.
Gee, I never knew there was a way to turn off non-sound decoders. If you are talking about sound decoders, I believe some of them use F6 to start up, and others use F9.
Craig,
This is the Home & Garden forum. You want the MR Electronics and DCC forum. [(-D]
Seriously, if you have locomotives with QSI decoders, all you need to do is to double-press F6 quickly and they will come to life. If they are newer Q2 decoders, you may need to do it twice to completely bring them up out of hibernation.
I have a BLI N&W Class J #611. It has a sound decoder. Tried F6 and F9 without results. Obviously, I am still doing something wrong. I have another locomotive that is a brass import with a Tsunami sound decoder. It too, is not working. Not certain what is wrong. I THINK that I TURNED OFF both of these locomotives before I ended the last operating session. That was in January. Work schedule, etc has kept me from working on the layout except scenery.[:(]
The first thing you need to do is determine if you have voltage on the track – something may have happened with your wiring that needs to be corrected.
If you don’t have a VOM, it would be a good idea to purchase a cheap one such as those sold by Harbor Freight so you can determine if you have voltage on the track or not.
and if you have power, I would do a reset. The decoder may have lost the address, it should not have but I know I have one loco that seems very susceptible to static electricity reseting the decoder and when it does not respond to its address, 03 alway makes it go.
It is fixed!![:D]
The problem was with the wires going from the command station to the Bus wires. The suitcase connecters did not work this time (my fault).[(-D]
Next up. Setting up second DB 150 as a booster and two PM42’s for district power management.[8-|]
On my throttle, the on off switch if the #8 button. Not F8.
