Just an interesting FYI:
On the new layout, I’ve got my logging branch laid - about 120’ of track.
I started dropping feeders from it, got about half-way round. “trigger finger” started to hurt, and I was just tired of soldering for the day… So thought I’d bag it.
Then, got a crazy urge to hook up the new NCE system and check the wireless out.
Slapped the first set of feeders into the system (20 ga. solid copper in staging area) and figured the loco would at least run a few yards either side of the feeder before signal fade/loss.
Set the wireless receiver on top of the benchwork - again, figuring it would pick up a signal at least there in the staging room…
Set it all up, put a loco on the tracks, put batteries in the throttle, cranked her up.
And away we go! All was well from the get-go. System performed flawlessly.
So then, I figure I’ll see how far the loco goes before the signal fades out… I ran it out of the staging area, and sent it on its way around a 120’ loop of track.
No problems. Went all the way 'round… off one set of 20ga. feeders yet!
So then I figure I’ll really push it and see how my wireless throttle signal is (given that the antenna is just sitting on the benchwork in staging, not properly hooked up).
So around the loco goes again, with me following this time, constantly fiddling the speed and setting off sounds.
Again, no problem.
Mind you, I have feeders every 6’ and every intention of running a full bus. I also will be mounting the receiver from the ceiling near the center of the layout. But it certainly removed most (if not all) of my DCC signal/wireless throttle worries! If I can run the sucker off 2, 20ga. wires and a receiver shoved in the corner of a separate room… That’s a good thing!
