DCC Replacement Board
I want to replace the original DC board with DCC board, with a replacement Digitrax DH165A0 DCC decoder board for my HO Bachmann Acela trainset locomotive. How will I wire this DCC replacement board to my locomotive?
If I understand you correctly, you wish to wire in a socket, and then drop in the DH165LO? If that is the case, you need to purchase a female 8 pin socket. Then you need to wire up the 8 pin socket to NMRA standards. This will then allow you to plug in your DH165LO.
David B
The “drop in” decoder replaces the lightboard, you don’t install it and then plug the decoder into it. The new ‘light board’ IS the decoder.
