creating this thrad because rich asked about it in another thread
trying to install a 2nd DCC Specialties Frog-AR Quad Output Frog Auto-Reverser being use to control 2 reversing sections, same as the first one. first one worked last time i checked
no track power because the same voltage (i.e. DCC phase is on both outputs frog 1&2
we soldered jumpers across J904 pins 1&2 and 3&4 so that each pair of frogs are used as an AR
we also soldered jumper across pins 1&2 J101-J801 to configure all circuits for 2A
when connected to both AR sections, the LED was lit, presumably indicating a short. disconnecting the connects to frogs 3&4 cleared that fault and i believe a track section may not be isolated. i believe this can be ignored for now with no connections to frogs 3&4
i measured 11+V between J901 pin2, and J903 pins 1&2. i believe 11V should be between only one J903 pins 1 or 2.
i also tried shorting across the gap at the end of the reversing section while measuring 11V on that track. i think i saw the voltage drop, but it returned to 11V when the short was removed
my next step would be to cut the jumpers on J101-801 but doubt this should fix the problem
i’ve emailed tony&#
