Dcc Specialties Hare
Anyone do any experimenting with setting up a Hare? I’ve used it with the peco insulfrog switches with success but last time being the same as this as far as setup goes I would like to have the trigger gap 3 switches away from the tortoise that will house the Hare , only problem I can see is each switch from the gap to the Hare will have the insulfrog breaking the solid rail. Any ideas at all?
Basicly where the lower green gap is on the inside rail is where I want to make my gap, how are the switches between the gap and the hare going to come into play?
And yes apparently you can make a two point break in the rail anywhere you want and as long as the wire is long enough to reach the Hare decoder it will work.
