Does anybody know if there is a potential problem with DCC switch machines (e.g. Circuitron Smail or Cobalt IP Digital) when the system powers up, especially following a power interruption?
I am thinking of the case where there may be a train standing over a turnout when power is interrupted - when power is restored, would these machines under any circumstances try to move the points, and so cause problems? Some sort of default position, perhaps initiated by the controller so it knows what its starting state is?
It clearly shouldn’t be an issue with direct-switched machines, like an old DC Tortoise or the equivalent Cobalt, and that is still one option for me. But the idea of using the DCC ones so I can set up routes has some appeal, and I’m now working through the pros and cons.
Thanks Trevor. That is sort of what I expected should happen, as it seems logical and safe.
I have an ESU ECoS controller but no switch motors as yet (just on the verge of starting layout construction). So thinking through the possible issues before committing.
I use NCE Switch-it and Switch8 boards for Tortoise/turnout control. Their default behavior is to STAY in the same position as they were when powered down, however they have an option to have them ‘exercise’ the turnout motor on power-up by changing the position and then moving back to the original position.
Thanks, OneWolf. That, plus the ‘route’ facility that most controllers have, suggests to me that whatever controller is being used, it must have the ability to read back the position of the switch motor so it can properly represent its position on whatever track diagram it shows. If I were to change the position of a switch manually by means of a push button wired to the Smail, for example, then doesn’t that new position have to find its way back to the controller somehow?
Or maybe they don’t bother? As I said, I haven’t deployed any of these things yet, so just trying to get all the details straight in my head first.
That may happen with ESU systems. The only other one I know this happens with is Digitrax with Loconet. Assuming the stationary decoder is compatible with Loconet and not a standalone device like a Smail.
For example, the Digitrix DS64 stationary decoder works via commands sent from the DCC controller, PLUS it can have local pushbuttons connected. When using this with a Digitrax system, if you look on the throttle and check the turnout address and it shows closed, if you press the pushbutton connected to that DS64 to change the points and then look on the controller again, it will show thrown.
However, this matters a lot less than you might thing. It doesn;t really matter which way the controller thinks the points are, if you tell it to set the points the same way they already appear to be, it will still send a DCC command out. What’s important, and most every DCC stationary decoder does this, is that the actual decoder remembers the last position so that at power up, all the point motors don’t go nuts trying to change to random positions.
LOL. I was going to add another sentence or two about my homemade controller, but since it’s not DCC I changed my mind.
I write the position to the EEPROM on the mico after each state change, and read the EEPROM on power up to determine where it should be.
The only reason it would move on power up is if comeone manually turned the servo to the opposite side.
ANd no, I do not continuously write to the same location, I actually implemented a scheme to spread out the writes across the entire memory to maximizes the total number of writes within the datasheet specifications for write endurance. It’s fairly low, like 10K writes is all the guarantee. My scheme needs 2 bytes, one for a counter and one for the two servo positions (top 4 bits are one server, bottom 4 are the other - so valid values are 0x00, 0x0F, 0xF0, or 0xFF). It writes 255 times to each location, then goes to the next (increments the address by 2) and writes 255 times there, and so on. When it reaches the end of the EEPROM, it’s not 128K writes but no more than 255 per memory location, and loops around and repeats. In doing so, there is one more pointer to the current memory location, which has only gotten written about 500 times - this is the limiting factor, but by the time that location has 10K writes, there have been some 2.5 MILLION position saves. Assuming you move one or the other servo 100 times a day, every day, that’s 70 years worth, minimum guaranteed by Atmel/Microchip. I won’t be here when it fails, and some people have written tortouse tests on ATMega chips and gotten close to 10x the rated duration without any bit errors. Plus there’s zero chance a given turnout will be changed 100 times a day, every single day of every week of every year. Even after I am retired there are other things I like to do besides run trains all day (shocking, I know).
I implemented a test mode in my original code with #IFDEF that did all the sequencing without actually writing,
