I am a relatively new user of the Prodigy Advance, I have learned enough to program the correct address to the locomotive and how to set some CV’s to allow me to turn on the headlight and rearlight independently no matter the direction of the locomotive, I currently am using Digitrax decoders on most of my loco’s, what I would like to know is what are the CV’s that control the dimming of the headlights both front and back and what is the correct value or variable that I use make this happen? If someone can help I would really be in heaven.
Step 2: Start on Page 39, that’s where it starts talking about the CVs that control the function outputs.
Now you need to figue out just what you want to do. You said you configured the lights to operate independently. It sounds liek what you want to do is have an F button turn the front light on and off, regardless of direction, another function to dim the front light, regardless of direction, another function to turn the rear light on and off regardless of direction, and a fourth function to dim the rear light, regardless of direction. I don’t think you can do this, it would have 2 functions controlling the same output and if one says “on” and the other says “dim” it’s going to be on. The standard way of doing this is to apply what’s called “Rule 17” since that’s the rule number in real railroad rulebooks covering the headlight brightness. Most decoder brands do this, certainly Digitrax ones do. This setting dims the light when moving in the opposite direction OR when you press a function key. The default is F4. So if you are moving forward and the headlight is on, pressing F4 would dim it. Or if you are moving forward with the headlight on, stop, and start moving in reverse - the headlight dims. You can’t take the direction qualifier off the Rule 17 dimming option. I’m pretty sure I’ve tried using a value of 40 in CV49 instead of the usual value of 68 for Rule 17, and it didn’t work. You can try it. If it works at all it would be 40 in CV49, 40 in CV50, and then 0 in CV34 and 2 in CV35 (F0 for headlight, F1 for rear light - if you’ve already changes these to something else you can leave it alone and use what you have). My guess is it won’t dim the lights when you press F4 with those settings. The values for dimming lights are normally CV49 = 104 and CV50 = 120. The 104 and 120 make it d
You will need to look at the Digitrax lighting effects area of the decoder manual for your decoder to see what you can change. Go to the Digitrax web site and click on ‘manuals & instructions’ Look at the manual for your decoder manual and the mobile decoder manual for complete information. Here is the URL for the mobile decoder manual:
Jim thank you as well. I will have to say that I am not very good with reading when it comes to these manuals. I don’t quite understand some of the things that they say any way I am very appreciative your help
I gave up trying to get my locos with Digitrax decoders to dim manually, NCE & TCS decoders have the option of manual control which has endeared them to my favorite decoder brands, in saying that two of my best running Locos (P2K GP7’s) have Digitrax decoders (DH-165LO), just can’t figure out how to dim the lights manually.
I too would be interested if any one has figured out how to do this. [sigh]
Randy I gave it a try and I did see the result that you were speaking of I guess I am really looking for the whole independent control aspect of DCC so I may have to try another type of decoder or just live with what I have and be happy.
Thanks again for your advice look forward to seeking advice from you again.
As well as Thanks to everyone who tried to help I am very appreciative of that
Just put 104 on CV49 and 120 in CV50. The headlight will be on if F0 is turned on and you are going forward. It will be dim when going in reverse, or at any time you turn on F4. Same with the rear light. If you don’t want the rear light to dim, just be on or off, set CV50 to 0 or 16. That one might be confusing - the example shows 00 for no effect but 00 would be on in forward direction, x10 (hex) would be on in reverse direction, which equals 16 decimal. I think 16 would give you rear light on when moving in reverse with F0 on, and the rear light off when moving forward with F0 on. Try both. I don’t have my old files from DecoderPro to see what I had in my GP7’s with DH163L0 decoders. But that’s the way I had mine set up - Rule 17 dimming on the front light and normal directional operation on the rear light.
Thanks Randy that works as you say, (CV 49 = 104, CV50 = 0) I didn’t want the lights to dim when changing direction but guess I will have to live with it in this case. The two GP7s will run in consist back to back so I wont be using their rear lights therefore rear dimming wont be required any way.
I like to set engines up that way because it allows you to keep the headlights on, yet confirm which direction you’re going to go since the light in that direction is brighter. BTW real engines don’t use reversing headlights like our models (light on in direction of travel only) but they were usually set up so the headlight could be on full, on dimmed, or off. For example, when meeting another train, a train stopped on a sidetrack would dim it’s headlight. You can simulate that by stopping the train and reversing direction without putting any power to the train (well at least with some systems you can) so the light is dimmed.
The TCS decoders have dimmed when stopped feature. They also have CV settings for dimming an LED or bulb.(Dimmed brightness) Also can be dimmed with a function press. I usually set mine up with dimmed when stopped and dim on F4. My switchers are set up with opposite light dimmed. Except the switchers that are run in pairs.
This is typically true when the engine is connected to a train. However, whenever I have seen engines running light (without cars) they usually have front on bright and rear on dim.
