Hi all,
I just bought the Lionel TMCC crane car and I’m trying to control it with DCS. However, I can’t figure out how to mimic the AUX 1-1, AUX 1-2, through AUX 1-6 buttons on the DCS handheld. The softkeys only offer AUX 0, AUX 2, AUX 7, AUX 8, and AUX 9. The TMCC section in my DCS owner’s manual isn’t a lot of help. I have sporadically gotten most of the various features to work on the crane by using AUX 0 but I’m having a heck of a time making it repeatable, and some features like turning the rear lights on and off, and launching the outriggers, I can’t get to work at all. Any suggestions short of buying a CAB-1?
Thanks for any help,
Joel
Joel
Feature DCS command
spin cab spin tumb wheel
front coupler cplr-f
rear coupler cplr-r
lower boom #2/brake
raise boom #2/boost
lower main hook (softkey) S2(AX2)/ brake
raise main hook (softkey) S2(AX2)/ boost
lower aux hook #3/brake
raise aux hook #3/boost
front lights on and off #5/key
rear lights on and off #6/key
launch out riggers drift
Any other number or soft key sends out the last command.
DCS appears to be unable to multi task the crane.
Everything works, I never would have figured this out on my own, thanks again!
BTW, for anyone else who has or is thinking about getting one of these cranes, I noticed that the outriggers don’t deploy properly unless the track voltage is pretty high, 16 or better. That’s a good reason to send the crane to your wreck site with a command-equipped locomotive.
Now I need to find a crane tender car.
Joel
The crane tenders shipped this week, A friend told me his was great matched up to the crane with the sounds.
If you don’t know: don’t turn the crane upside down with out the lines tied off or the will unwind in a second.
My out riggers pop at 18v.
