Hi all, I usually try to trouble shoot all of my issues with Google and trial and error but I’ve hit a wall with a DCC issue and I need some ideas. I apologise in advance if it’s long winded or if I sound like a newbie, but I really am.
I have 7 Athearn Genesis DCC ready SD70ACes that I have been attempting to put non sound decoders in. I used the Digitrax decoder selector on their website to select the DH166 and due to availability, I’ve had to order them from different vendors and I’ve finally managed to get 7 of them . I’ve done 3 installs so far and I’m finding that all 3 of the locomotives react the same way in that they will lurch forward in small bursts before eventually taking off on their own, stopping only when power is killed to the track. When in reverse, turning on the 0 function for headlight will illuminate the rear headlight and all other functions will cease to work, no movement, no ability to turn the headlight off, it basically turns into a brick until cutting power to the track and disabling the 0 function and turning it back on. These installs are directly from package to locomotive to track, I haven’t even attempted to program them aside from setting CV8 to 8 in an attempt to reset the decoder.
I have a Digitrax DCS51 and it seems to run other locomotives that have had DCC previously installed without flaws, including other Athearn SD70ACes . I’ve also tested with intermountain ES44s that came with factory installed decoders and they operate without an issue.
The closest explanation I’ve found was a gentleman that was experiencing the engines moving on their own at a club and was told his DCS51 was bad ordered . Is there a way that a power pack can send corrupt data packages to only certain types of decoders ? If it IS the power pack, would there be an explanation as to why only those installs are acting up ? I couldn’t imagine that 3 decoders from 2 different vendors so far
