Please go ahead and roll your eyes now, just to get it out of the way. [:D]
I remembered today that I have a Spectrum 4-8-2 mountain that I bought years ago on ebay. One of the reasons I had forgotten about it is I never had any way to test it - no power pack, etc. When I finally got a powerpack last fall, I tried to run it, but the model wouldn’t move. I packed it up in the box, and there it sat until today.
So being much more wiser in these things than I used to. I took apart the tender, and lo and behold, there was a digitrax DH 121 decoder plugged into the board. I took it over to the programming track, set a new address, and stuck it on the layout.
It moved down the track about 15 inches, and stopped after it passed a feeder wire. I pushed it back, and it reversed back down the line, until it passed a different feeder, it just stopped dead.
I figured the decoder might be bad, so I swapped out the digitrax with a bachmann one that came from a consolidtion. Nothing, wouldn’t move, wouldn’t let me programm the address
I removed a tender from a 2-10-0 that I have (also spectrum) that runs well, and attached it to the mountain. Nothing. Wouldn’t move or respond.
I put the digitrax back in, and still nothing. Reprogramming the address failed, failed, failed, took. MY CVP controller was giving me wierd messages; told me it was not a 3 type decoder when i went to reset the defaults on CV8, than took it.
So what do you think I’m looking at here.
A bad loco?
A bad decoder?
Both?
I’m kinda leading towards a bad loco, as the spectrum decoder I put in was working fine on the consolidation before I replaced it. With the 2-10-0 tender, can you just swap these out like that? I figued it should work, as the wiring should be the same on each.
Thanks in Advance.
