Decals GRRRRRRRRRRRRRRRRRRRRR !
They just won’t stay on
I followed the instructions even used the setting solution
let them dry over night but when touched they fall off
GRRRRRRRRRRRRRRRRRRR !
Quite frankly, hard to have decals fall off if you followed directions. I have used about all the brands for years and they do stay on. Which means, there must be something in the way you did it that was faulty. Why don’t you list, step by step, what you did, what decals they are, what brand, what setting solution, etc. Then maybe we can spot what went wrong.
Bob
Sounds to me you decaled over an unpainted surface. Decals will not stick to bare plastic,wood,metal etc. The glues nad setting solution need a painted surface to work on. A glossy one is best.
Dan
No Dan These are on the number boards of my Athearn F 7
and they are painted along with the rest of the body shell
I’ll up load a photo later tonight after my video finishes uploading
Decals, if properly applied, don’t fall off. I thjink you may have left out the step which says to overcoat the decals with a clear flat or gloss.
As one who has made custom decals professionally, I can tell you what the steps should be:
  1. Wash the model carefully with soap (I prefer Dawn dishwashing detergent) and water, using a soft brush to gently scrub it clean, then rinse thoroughly.
  2. Pat dry with tissue, then let the model air dry. DO NOT TOUCH THE MODEL WITH BARE FINGERS AFTER THIS POINT! (At least until after step #8.)
  3. Spray a gloss finish on the entire model ( some folks will advocate just spraying the area to be decaled, but to ensure a uniform finish, I spray the entire model). Let dry completely!
  4. Apply a generous amount of Microscale’s Micro Set to the area to be decaled. At the same time, dip the decal into distilled water long enough to get the paper backing thoroughly wet. Set the decal aside on a non-porous surface.
  5. When the decal will slide on the backing, it is ready to apply. Slide it onto the model and move it into its final position. Let dry completely.
  6. Very gently apply the setting solution of your choice. I prefer Walthers Solvaset. DO NOT touch the decal itself while doing this. Drag a drop over the surface, replenishing the drop as necessary to get the entire surface of the decal covered. LET DRY COMPLETELY! (Overnight is good.)
  7. Inspect the decal for whitish areas which indicate that the decal has not settled down completely. Prick these areas very carefully with the tip of a #11 blade or a very sharp pin, the re-apply the setting solution as in step #6. Again, LET DRY COMPLETELY. Repeat #6 & #7 as necessary.
  8. When again dry, and when no whitish areas are present, you should now overcoat the decals with a sprayed gloss finish. When that
Well Bob
as per the instructions in the champ package
I painted the area with a small amount of decal set
I soaked the decals in a plate of water and waited till they floated free then
picked the up by the corner with tweezers and applied them
i removed the excess water by touching the decal at the base
with the corner of a paper towel
then let them dry over night
when i touched then the next morning they fell off
If you soaked them long enough for the decal itself to separate from the backing paper, then float around in the water, the adhesive may have washed off the back of the decal. You only need to soak the decal about 10-20 seconds - just long enough to saturate the backing paper with water, but not so long that the decal lifts off of the backing paper. After removing from the water, let it sit for a few seconds, then the decal should be able to slide around on the backing paper. When applying the decal to the model, slide the decal off the backing paper directly onto the surface of the model (I use a toothpick dipped in distilled water to do that).
A couple of things that may be your problem is leaving the decals in till they float off the paper, and not blotting the decal before applying it as in gmcrail’s post, steps 4 and 5.
I lay the decal, still on the backing, on a paper towel after a soak of maybe 20 seconds. Without blotting it off, all that water will dilute the decal set. The smaller the decal, the more water will adhere to it relative to it’s size which dilutes the decal solution even more.
After a shorter soak in the water the decal will still slide off the paper with a little assist from a toothpick, piece of plastic, or a modeling knife. After the decal is applied you still blot the excess setting solution from under the decal.
Hope this helps.
George V.
[quote user=“gmcrail”]
Snip
Well there’s nothing in the instructions about doing this
Nope didn’t do that
  1. Pat dry with tissue, then let the model air dry. DO NOT TOUCH THE MODEL WITH BARE FINGERS AFTER THIS POINT! (At least until after step #8.)
The numberboards are not an area you would touch
  1. Spray a gloss finish on the entire model ( some folks will advocate just spraying the area to be decaled, but to ensure a uniform finish, I spray the entire model). Let dry completely!
Nope nothing in the instructions about that either
  1. Apply a generous amount of Microscale’s Micro Set to the area to be decaled. At the same time, dip the decal into distilled water long enough to get the paper backing thoroughly wet. Set the decal aside on a non-porous surface.
Did That !
  1. When the decal will slide on the backing, it is ready to apply. Slide it onto the model and move it into its final position. Let dry completely.
In the instructions they go to great lengths to tell you you can let it soak as long as you want
and they say if you slide it off the paper too early your results won’t be as good
Honest !
  1. Very gently apply the setting solution of your choice. I prefer Walthers Solvaset. DO NOT touch the decal itself while doing this. Drag a drop over the surface, replenishing the
Terry:
I used to run into problems with Champ decals, just like you’re experiencing. Usually, when I was trying to decal loco numberboards. After trial and error, I found that ignoring the instructions about letting the decals float free, and applying them directly from the soaked paper to a Glosscoated surface on the numberboard casting while there was still a slick undercoating, helped a lot. Then I would flood them with either Microset or DecalSet (Champ’s version of the same thing) and letting them dry, then flooding them again about three more times, would usually set them enough that I when finally dry (overnight), I could overspray them with Dullcote and have them stick on permanently.
The Champ decals are about twice the thickness of the Microscale decals (though I like them better for small detail work), and take a lot more TLC to get ‘set’ on the surface. The trick is to apply them from the decal sheet when they’re ‘sliding’ and not floating free.
Well Tom what you and some of the other guys are saying here makes sense cause following their instructions sure doesn’t work
Here’s a picture of the number boards
Pretty small and difficult stuff to work with
A larger picture showing the decals and the solvent
I wouldn’t have to do this if Athearn could come even close to using the correct road numbers
MicroSet is only a “setting” solution. It’s purpose is to evacuate the water and air under the decal and pre-soften it (the pre-softening mainly works with thin decals, not so much with the thicker Champ’s).
Once the Microset is dry, you need to apply multiple coats of MicroSol, (this is Microscale’s solvent}. Between each application of Microsol, look for those frosty spots and air pockets and open them as others have described anjd re-apply the Microsol. You can speed things up with a hair dryer. It can take 2-5 courses (Microsol, drying, Microsol, drying,etc) to get the decals to conform to the surface and stick. Do not touch the decal at anytime with anything other than a soft brush. When completely dry apply finish of your choice.
Contrary to popular belief, the glue that is used is not intended to “glue” the decal to the model, it is only there to hold the decal to the paper backing. By not letting the decal float off the paper, one risks discoloration of the decal over time, (this isn’t so much a problem today as better non yellowing glues are used). Decals adhere to surfaces by a “welded” bond to the paint, created by the solvent’s softening of the decal., (sorta like welding 2 pieces of styrene with liquid plastic cement), which is also why decals don’t stick well to bare plastic.
I have been custom painting and decalling for 30+ years and have had many discussions with the various major decal manufacturers over the years. The best system I have found for consistent results is Microscale’s Microset/Microsol, but you must use both. (I do not work for Microscale!)
Champ decals were originally produced when the original Wlathers Solvaset was around, (which was much stronger than todays version), as decals of the day were much thicker then, Champ never changed their product.
Terry.I have used Champ decals for years…
Here’s my method…
1.Place decal in water and let it set till the decal will slide from backing.
2.Apply decal by holding and with small tip paint brush slide from backing…
3.Let the decal “set”.
4.Apply Champ Decal solution.Let dry at least 24 hours before decaling the other side.
I used the same method with custom made decals.
Nice looking work Larry
guess I’ll have to get some of that decal solution stuff
or maybe get out the white glue
they had fallen off again last night
Yes you are leaving off a key step. Regardless of whether you use a setting solution before putting down the decal or not (I usually don’t), as soon as it’s fairly dry you need to add one or more applications of Micro-Sol or Solvaset to ‘snuggle’ the decal down. I usually first just touch one corner of the decal with Solvaset, just enough to hold it in place when it’s dried. (Capillary action usually moves setting solution under the entire decal.) Then after that has dried and the decal is in place, I add a wash over the whole decal. You may need to make tiny slits with a razorblade or X-acto knife to open up air bubbles or areas where the decal isn’t laying flat (like around rivets) and then add more Solvaset or Micro-Sol.
If the decal moves after applying the setting solution, you only have a few seconds to get it in place before the decal will start to “melt”. That’s why you have to be careful. Often I’ll put a drop on the model and tilt it slightly so gravity slowly pulls the drop to the decal.
Otherwise, unless the decal moves and you have to do a quick fix DON’T DO ANYTHING until it’s dried. It may wrinkle the decal and make it look funny, but it will smooth out as it dries. [:)]
On a woodsided car, once the decal is in place and dry, I take a single edge razor blade and slide it in the grooves between every board and then reapply setting solution. If you don’t do this there will be gaps where the decal is floating on air between the boards.
I still think we are missing something in what he is doing or not doing that causes them not to stick at all. I have been decalling longer than most of you have been alive. I follow basic steps, but I don’t get as elaborate as some of you and still have no problems. Champ, Micro, what ever the brand. I make sure the surface is clean and has a gloss, plop the decal in a container of warm water, lift it out on my finger or with a pair of tweezers depending on decal size, slap it on, blot it and let it dry for a bit, then the Walthers Solva set application, then after 6 hours or so, the dullcote. Seldom ruin one, they look correct when they dry, and I don’t consider it brain surgery to perform.
I just put new numberboard decals in two Kato SD40-2 engines yesterday and they are just fine, do not fall off, and look normal. I still believe there is something he is doing that we are missing.
I am not trying to insult you or anything else, just trying to figure out what is going on, so I am going to ask you one very simple basic question…you are getting the decal off the paper before you apply them, aren’t you???
Bob
I still think too much water initially is the prob. I use only a few drops on a ceramic tile,just enough to wet the paper for about 20 sec or so until they can slide, then transfer.The recieving surface needs to be moist so you can position the decal. Setting solution on over the top,in small amounts. BILL
I think you’re on the right track, Bill. When I do number boards, or other small decals, I don’t even dunk them. I place them on the end of my finger, then place a drop of water on the decal by picking the drop up with a closed set of tweezers and carefully opening the tweezer over the decal. While that’s soaking - a matter of 10 seconds or so - I brush some Micro-Set on the surface to be decaled. Then follow the steps in my previous post.
Here’s a boxcar done that way, and incidentally, it was done on bare plastic - a Kadee 40’ PS-1 kit - I liked the color of the plastic, so why paint it? The decals don’t fall off, either. [:)]
The repack data (to the left of the ladder) and the “Return When Empty” statement (to the left of the door) are separately-applied decals.
I think the problem is he’s putting down setting solution and then putting the wet decal on it. The water is diluting the setting solution. Then that’s it, he’s not going back and doing an application of Solvaset or other setting solution. I suspect when tries that final step he will get much better results.
SPECULATION:
The decal is supposed to have a layer of glue below the clear decal film. Due to manufacturing error, there is no glue on Terry’s sample. Hence, decal does not stick to car.
I also wonder whether Champ put the glue on top of the decal with the idea being that it was supposed to be “glued on” from the inside. Ya never know…
NOT SPECULATION:
I’ll also mention that after decaling cars and after using decal solvent, I have washed off the excess glue with a paint brush under lightly running water. I’ve never had a decal come off.
Ed
