Will the model decals we use on our trains also work on wood? Anything special need to be done other than making sure to have a clean smooth surface and then sealing the decal to protect it?
Decals work on wood just fine.
All you need is a glossy finish and some good decal softener to snuggle the decal into the texture of the wood.
-Kevin
Thanks!
The need for the glossy finish can be the challenge in certain situations both for rolling stock and structures. Sometimes you want a very aged weatherbeaten appearance to the wood but nonetheless want a decal on it. Merely putting Dullcote over the end product once it has been made glossy does not bring back the texture of the wood that I seek. I myself have yet to find a really satisfactory way to do it.
Dave Nelson
Dave,
I have found using Future (not Future any more, can’t recall the new name) floor polish applied with a brush makes the area for the decal glossy without filling in the wood texture. I use “DACO Strong” to settle the decal, then brush on Vallejo Matt Varnish to dull the shine.
The results are pretty good.
-Kevin
Dey transfers seem to work better on wood as long as the surface is not too fuzzy
Future is now Pledge Floor Care Multi-Surface Finish (try saying that three times fast)
https://www.pledge.com/en-us/products/pledge-floor-care-multi-surface-finish
Eric
Remember when railroad decal lines were first made (like Champ and Walthers), 90%+ of all model railroad freight cars were wood kits…so really, railroad decals were originally designed to be used on wood.
If you’re doing a wood-sided car (actual wood or plastic), one thing I find helps is, after the decal is firmly seated down with Solvaset or something similar, to take a single-edge razor blade and slide it down the grooves between the boards of the car and then add more Solvaset. I find if you don’t do that, the decal never fully snuggles down into the grooves and the end result looks like a car with a decal on it. Cutting it into many pieces and adding Solvaset again makes it look more like a wood car with painted-on lettering.
I’ve been doing it that way (Stix) for 40 years and always been happy with the results.
Mel
My Model Railroad
Bakersfield, California
