Hi,
My late father introduced me whith Nscale just when Arnold Rapido made his first release ( ? 1969 or 1970…)
He was modeling in HO scale because at this time N don’t exist.
He switched immediately to Nscale, first whith Rapido and after whith the other European manufacturer (I live in Belgium).
I switched myself to American prototype first because of a excellent working coupler, Kadee; second because of the magnificent trains running in the US in the 40’s.
I have only modeled in N scale and at 53 years I am still completely convinced by Ns cale.
Father and me where looking for realistic looking trains, including track, curves and long trains and I forget to say Nscale offer a good ratio between trains and scenery.
All of us in HO or Nscale, if you are correct with your answer for this post, we must admit we have no good running engines before 1988-1990 in HO or N scale out of the box (generally); sure the advance in HO was noticeable in the 90’s but from 2000 the engines were good runners from the box in the two scales; so the running problem is not a good factor choice!
(post edited by moderator)
There is three basic rules in any scale if you are asking for a good running layout: electrical continuity, perfect track, well gaged wheels; just in N scale I must confess, these rules are on the edge.
So check and recheck and check again your track, use only body mount coupler,put only broad curves which is not a problem with your space, and don’t forget you can run easily trains of 20-25 cars.
Sure I am still convinced by N after all these years.
At 53 I just begun to build a very big layout in a 65X26 room…in N scale and I wear glasses!
HO had give us superb layout but N scale too.
Cheers
Marc
I am in the way to build a very big N sclae layout with an around 500 feet of mainline set
