Decoder for SD70M
Hi, I recently purchased an Athearn Genesis SD70M. I would like to add a decoder to it but not sure what to use since the ditch lights are 1.5 volts. Do I need to add resisters for the ditch lights or is there a decoder so equipped?
Don
A TCS A6X decoder should be an exact board replacement for the constant lighting board that is in the Genesis SD70M, and it supports the 1.5 Volt bulbs used by Athearn.
http://www.tcsdcc.com/Customer_Content/Products/Decoders/HO-Scale/A-Series/A-Series.htm
Thanks for the info.
Don
