Hello All,
Bachmann decoders are extremely simple and only support 13 Configuration Variables (CVs) while most other decoders support over 60 CVs.
I have a Bachmann GE 70 tonner in my roster. I also use JMRI Decoder Pro through a Digitrax PR3 to a separate programming track from my desktop Mac.
My DCC system is the Bachmann Dynamis with the 5 A booster and the ProBox.
I added a NCE Auto SW Program Track Auto Switch so I could have a programming track on the pike through the Bachmann DCC system.
Having the Bachmann DCC system is no advantage when dealing with the decoders of the same brand.
Are you “programming on the main” (POM) or do you have a dedicated programming track?
First, I would recommend a decoder reset; CV 8 to a value of 8. This will set the address to the default of “3” and restore the factory-set CVs.
The decoder needs to be set to accept 4-digit addresses. These are controlled through CVs 17 & 18.
Even if you don’t have the ability to run JMRI to a programming track you can still download the program and use it as a CV calculator.
To do this, download and install the Decoder Pro program; available for Windows and Mac.
When you open the application don’t worry if you get an initial error message of “Unable to connect to Loco Net…” Choose the “Start With New Profile” option.
Once open hit the “New Loco” button in the upper left. This will open a list of supported decoders.
From the list toggle open the Bachmann folder, toggle open the E-Z Command decoders folder and choose the 2-function decoder (36-552).
At the lower left you will see a button marked Open Comprehensive Programmer. Hit this to open the programming window.
On the top of this window there will be several page options. Go the Basic page.
Choose the radio button marked
