Decoder problem
i am hopping someone can help i have installed some decoders into somedcc ready piko trains two with a piko decoder and2 with a lenz one (all 8 pin)now my problen is getting lights to work
i have to controllers the pike light and the the more expensive on which is wireless on the wire less one i can turn lights on and off but not on the other controller i set up each loco by reading them with the wireless one i must have done somthing on creating a loco on the light contoller but not sure what to confuss things one of the locs the lights work no idea what i did this is my first attempt a ddc or ac so please be kind i know i have a lot to learn
I really hate to respond this way, but would it be possible for you to use caps and punctuation for us old geezers? 13 hours with no reply probably means nobody feels they can help you, quite possibly because reading and comprehending your situation is simply too difficult.
Have you followed an instruction or a video to do this? You’ll have to confirm each step. Also, contact the decoder sellers and ask them for help.
[#welcome] to the forum. Intial posts have to go through moderation so maybe your post didn’t appear as fast as Selector would have liked.
We don’t see much discussion of Piko and Lenz and as you are using both, English may not be your first language. Usually we can deal with that, but run on sentences make it especially hard.
That said, we have no idea what contollers you are using. There is no Pike Light on the Piko webpage, but there is this https://www.piko-america.com/collections/piko-smartcontrol/products/55016-smartcontroller-light-ho-n-tt-scale
No idea what the more expensive one is.
[#welcome]
As a new member you are under moderation for the next few post and your posts are delayed. You might be able to edit your existing post so we could understand what your problem is.
Mel
My Model Railroad
Bakersfield, California
Well of course the standard answer to many decoder issues is “do a factory re-set and see what happens”. The instructions for each decoder should explain how to do that; it usually is just changing a CV to a specific number and then removing the engine from power for a moment.
And of course, if the lights don’t go on and the engine runs in reverse when you want it to go forward, you put the decoder in the wrong way around. Remove, rotate 180 degrees, and plug it back and try the engine again.
Thank you wjstix for your reply. I have checked that the chip is in the right way (orange wire to pin number1).
The decoders I have are German so it’s taking awhile to go through the instructions. Two seem to be working and I am not having any luck with 2 which have the lenz chip.
I am very sure that it is something I am doing but just not sure what. Having 2 types of controllers is not helping I will have to with on at some point I know.
Is it possible to insert pictures into a post I am not sure if that is allowed?
In reply to the first reply, I apologize for my poor grammar I surfed a stroke a couple of years ago and some of my skills are still working their way back. I tend to just act and not take care to see what I have done.
Any help is gratefully received. I am really keen to learn as much as I can, so I can start to develop my layout.
This is a link to the other contoller
https://www.gaugemasterretail.com/magento/piko-pk55040.html
