First, hi Randy, Joe and Nigel (I suspect the title will draw them here!).
I am in the process of painting, re-wheeling and equipping a fleet of Life Like N-scale FA2s and FB2s. Since these are carbody units, the A’s have a single headlight and will get a rotary beacon installed. The B’s will have neither.
It seems like any decoder that will fit the B can work without regard for the number of functions. I was originally thinking the A’s needed 3-function decoders minimum (the two normally associated with headlights and one for the beacon). However, I overlooked the obvious - they have only one headlight. As I see it, both the headlight and beacon will be non-directional (by choice). The only requirement is that there be a beacon effect for the beacon. So, is there any case to be made for anything more than a 2-function decoder?
What has me confused is that the Digitrax decoder manual states that for single-headlight locos you tie the white and yellow leads together. If true, that means I need the third function (Green lead) for the beacon. But, unless I am missing something, this can all be established through two functions and CVs 49 and 50.
What this all boils down to is the choice between TCS M1/Digitrax DZ123 or TCS M3/Digitrax DZ143.
