I have an older Bowser s-12 with the 8-pin connector. I bought one of the my usual drop in decoders (NCE NCE5240103). What I didnt’ realize is I need to use the extender pins to clear an obstruction on the board. If I use the extender pins, the hood doesn’t close all the way.
Does anyone have a recommendation for either a: a cable that will let me use the decoder I have to clear the board, or a decoder they usually use for these switchers?
The lightboard in the DS-4-4-1000 appears to be the same lightboard in Randy’s VO-1000 photo and the DP2X needs no harness. I would think it should also work in your S-12, since they have similar shells.
Can you post a photo of your S-12 chassis with the lightboard?
My hobby store had a Digitrax decoder with a harness that worked. It was still a tight fit. My dis-4-4-1000 I could use the non-harnessed decoder, but the s-12 was just a slight difference on the shell.
