Decoder selection for Bowser steam engines
I have built Bowser/Penn Line K-4 Pacific, E-6 Atlantic, I-1 Decapod, Consolidation, and have a T-1 in the shop. All the built engines have DC-70 motors which I have isolated from the frame. I’m ready for a decoder install. I don’t see any web postings for decoder installs on these engines…Anyone? Thks.
I have several Bowser DC70/DC71 locomotives all wired for DCC. I have used MRC, Digitrax and Soundtraxx decoders and all work OK. I have never liked the brush/commutator arcing of the DC70/DC71 motors so I put back to back Zener diodes (1N5355) across the brushes to reduce the voltage spikes to the decoder.
I haven’t lost a decoder driving a DC70 or DC71 motor but be warned locked rotor can be well over 1 amp.
Mel
My Model Railroad
Bakersfield, California
Thanks Mel…I’ve enjoyed your blog for years. I found a prior posting from you…same subject.
I use two 18 volt 5 watt Zener diodes (1N5355) back to back across the motor power wires. I have never had a decoder go bad in any of my Athearn BBs with the diodes installed.
Question…to get forward and reverse protection do I need two pairs of Zeners??
You only need two Zeners, I install mine negative to negative in series with the two positives across the motor brushes per the drawing (left pair in the drawing).
Mel
I have a couple of Boswer Steam Locomotives, a Casey Jones and an H-9, but both have the “newer” DC-71 motor ready for DCC, with the skewed armature. I used TCS T1s in both, and they work just fine. I can’t afford sound at the moment. I’m building an E-6 now, and that has the newer motor, too, so I’ll probably put a T1 in that as well.
I’ve recently acquired a couple of Bowser kits with older motors waiting in the build pile, so I may look into the diodes Mel references.
