I experienced a very odd situation on my layout yesterday.
I decided to run a Proto 2000 G9 which had not been run in awhile. So, I powered it up and ran it out of my diesel servicing facility onto the main line track. As it moved through a double slip, one wheelset derailed and the resulting short shut down my DCC booster, an NCE PH-Pro 5 amp system.
The loco did not fall over or anything else very dramatic. Just one wheelset derailed. Once I put the loco back on the rails, it was sparking, making electrical buzzing sounds, and continually shorting out the system.
Alarmed, I pulled the loco off the main line track and decided to test the decoder on my programming track. Nothing. Cannot read CV. Incidentally, the decoder was an NCE P2K-SR.
I have fried a few decoders in my time, once or twice due to my own installation errors, once due to a manufacturing flaw on a Life Like S3. But, I simply could not believe that I fried this one.
I took the shell off of the chassis to look at the decoder. Everything seemed OK. I replaced the decoder with the original DC circuit board and ran it on a DC test track. It ran fine.
So, then I tested the decoder with my NCE DTK and, to my surprise, everything tested out OK. So, I put the decoder back into the loco and tested it once again on the main line track, and it ran fine.
The only explanation that I can offer is that the decoder became unseated during the derailment with the 8-pin connector slightly separating from the small circuit board chip.
Anyone else have this experience or want to offer an alternative explanation?
