Deleting a Post
Somehow, I double Posted on Re: Clouds, do they have scale ? I tried Hyperlink and Delete, and then tried to Backspace the entire Post , and when I reposted. the unwanted Post was still there. What do you do to delete and unwanted Post ?? Bob Hahn
The delete only shows until someone replies. If you back up or refresh while typeing a post, it usually goes away, so if int he middle of typing something you need to go reference something else, select allt eh textin your message and do control-c or copy first so in case the text disappears you can hit control-v or paste to get back all that typing you did.
From the forum FAQ:
How do I delete my posts?
If the forum you posted in is configured to allow deleting of posts, you will see a button labeled “Delete” next to posts you have made. If other members have replied to your post you will no longer be able to delete your post. If you want a post removed but are unable to delete it, you are encouraged to contact an administrator or moderator.
Paul
Edit the unwanted post, and enter a long winded political rant about the politician of your choice. It doesn’t matter which party. Then the moderators will delete the post for you. ROFL.
[:D] Good idea!!! [:D]
