I KNOW THAT HO SCALE IS NOT THE RIGHT SCALE TO USE IN THE GARDEN RAILWAYS BUT HOWEVER I CANT AFFORD TO UPGRADE. I HAVE YEARS OF TIME INVESTED IN MY HO SCALE BUT NEVER HAD THEM OUTSIDE. I DECEIDED TO TRY IT OUT. WHAT THE PROBLEM IS IS THAT AS I LAY TRACK AND TEST IT OUT AS I GO ALONG THE LOCO RUNS OK BUT AS SOON AS I PUT STOCK ON THE LOCOMOTIVE IT DERAILS. ALSO IN THE SAME SECTION OF TRACK A DIFFERENT LOCOMOTIVE WILL DERAIL WITHOUT THE ROLLING STOCK. HERE IS HOW THE TRACK IS SITTING OUT THERE. I DUG A TRENCH WHERE THE TRACK IS TO BE LAYED I THEN USED PIECES OF FLAT CONCRETE IN THE TRENCH THEN LAYED MY TRACK ON THAT. I KNOW THAT THE TRACK HAS TO BE LEVELD FOR ALL TO WORK SMOOTHLY WHICH I HAVE CHECKED. IN SOME SPOTS A LOCOMOTIVE WILL RUN FINE THEN WHEN I SWITCH LOCOMOTIVES THAT ONE WILL DERAIL…HELP WHAT DO I DO. I ALSO KNOW THAT HO TRACKS WONT LAST OUTSIDE BUT I WANTED TO TRY IT OUT. SHOULD I JUST GIVE UP THE IDEA OF LAYING HO SCALE OUTSIDE. I ALSO HAD MY LOCOS CHECKED OUT AND SERVICED AT MY LHS. HELP HELP HELP
THANKS ALL.
