Designing a layout, is there a similar prototype
Thought the collective might be helpful. Working on designing a new layout. Started wondering if there might be a prototype some where that is or might be similar. Region isn’t specific, nor is the railroad, nor is the era. Could be regional or a short line or major line. It would encompass operations at a port, urban area, rural area, maybe quarry, farm coop, Thought I would ask if anybody knew of one that is of a similar type all or in part. Was looking for a prototype to help as a guide line in the design.
shane
Jiust off the top of my head Lackawanna, Erie, New Haven, Boston and Albany, Boston and Maine
1-Ports = New York and Boston
2-Urban = New York and Boston Commuter Zones
3-Rural = North West New Jersey, Southern New York, Connecticut East of New Haven, Western & Southerrn Massachusetts
4- Farms, Quarries - Yes
When you think ports, don’t forget or ignore Great Lakes ports, which often have the urban and rural elements of their operations in pretty close proximity. Duluth/Superior for example.
Dave Nelson
Now I didn’t think of the Great Lakes. Good point and place to look
Good suggestions so far.
I am currently working on a 4’ by 8’ N scale layout of the Ventura County Railroad in California. The VCR is a short line railroad serving the Port of Hueneme, a Navy SeaBee base, the town of Oxnard and the immediately surrounding area with an interchange with the Union Pacific (formerly Southern Pacific). The real beauty of this railroad is that it used to be a complete loop of track (kind of a rectangle with rounded corners). The layout could indeed be a good mix of Urban and Rural scenes depending on the era modeled. If you model the WWII era, most of the area was rural with a few agricultural clients served. The area became more urbanized as time moved on.
Check this area out on Google Maps as well as on www.historicaerials.com. You can see how the tracks used to be continuous through the harbor area in the early days on www.historicaerials.com. Currently, import car manufacturers use this port to offload car carrier ships. The Navy base is still active and military ships still use the harbor. A freight car sorting yard exists on the base property and the various Navy warehouse areas are rail served. Various other rail served industries along this line have changed over the years so a particular era could offer most everything your are looking for.
The N scale track plan I am working on locates a portion of the Port of Hueneme in the southwest corner of the 4’ by 8’ layout. The Navy base takes up most of the west half of the layout and a three track interchange yard is located in the northeast corner of the layout. I included a passing siding and several spurs along the east side of the layout to add industries for switching operations. Much of these areas are used for import auto storage in the present era.
I displayed this layout under construction during a re
There was a layout plan in MR recently - by recently probably the last 5 years, but maybe a bit older than that, which was either themed on the Ann Arbor Railroad or Detroit, Toledo, & Ironton, which had port (including a carfloat), and rural operations in a pretty compact space.
Ann Arbor is a good example of this, particularly if you look at some of the ports they operated on Lake Michigan in the Upper Peninsula, which had very dense downtowns that give that Urban running feeling but pretty quickly transition to rugged countryside. Having a carfloat in a port is a great way to have staging for a small layout too.
Second that. Busy seaports, compact urban areas, rural as rural can get, farmland and quarries everywhere.
Portland, Brunswick, or some invented town on Casco or Penobscot Bay gets you everything.
Santa Fe & SP in Richmond, Ca. on the shores of San Francisco Bay, (now BNSF & UP). Classification-hump yard, Port of Richmond (up until mid-80s carfloat operations), big oil refinery. Many and varied industries depending on era: fertilizer & chemical plants, ship yards, canneries, automobile & Pullman car mfg., whaling station (until 1972), naval fuel depot, quarry and brick mfg., etc. Urban not rural. tunnel & wig-wag signal protected crossing.
Regards, Peter
DT&I in Michigan and Ohio, serves the Ford plant and port at River Rouge, various other auto parts plants in Michigan. Toledo has auto parts plants and General Mills cereal plant. Further down in Napoleon is the massive Campbell’s Soup plant. Then in Lima the Ford Engine plant. As you get further south there are grain elevators and feed mills.
Rick Jesionowski
For anyone wanting info on busy ports: https://www.atsinc.com/blog/busiest-us-ports-how-to-choose-one.
Depending on the layout size, it seems you’ve got a lot of variety happening.
A couple of smaller lines out of New York harbor: New York, Susquehanna & Western; and New York, Ontario and Western (abandoned in the 1950s). The had everything you asked for, plus coal until the 1950s
working on making the layout smaller and finishable. following the rule there is always a prototype. Using that as a guide. 10x12 is the space. possibly 10x14. By avoiding intermodal ports, i can squeeze a decent port in a modern era layout. foloowing the northeart ports, some on thegulf, misiippii and lakes. that would be old ports in use. same with the urban city trackage. a general port format idea is easy. I have a basic idea there.no track plan. just a basic idea of what will work that can be adjusted accordingly. its everything else that is the challange. my creativity an inspiration dried up. its a new spark that is needed.
shane
What scale are you working in?
Here is a Google satellite view of a Chicago port on Lake Michigan, apparently run by the State of Illinois. You can zoom in to see track arrangement. Looks like lots of steel and lumber type cargo.
https://www.google.com/maps/@41.7276104,-87.5337289,1052m/data=!3m1!1e3?authuser=0&entry=ttu
If you’re looking at modern, the Port of Duluth was quite interesting when I went by a few years ago. They get some big ships, mostly lakers but some salties too, carrying various things. You could get away with lumber, bulk materials (gravel) and of course iron ore in the area. It goes pretty much immediately rural once you get out of the city. As an added bonus if you are doing pure prototype, the Lake Superior Railroad Museum in Duluth runs steam exclusion services, and takes visitor motive power/excursions (it was visited by the UP 4014 a few years back), so you have a prototype justification for any steam you want on the modern layout.
When I was there a few years ago they were routinely getting in shipments of wind turbine components, but I believe those would be shipped by oversized truck. Looking at google maps, there’s grain elevators, aggregates, and scrap as the main harbor industries besides the couple of ore docks still kicking around.
I model the Milwaukee, not terribly prototypically, in the Transition Era. It did engage in carfloat operations through smaller lines like the Ann Arbor and Port Huron and Detroit. Carfloat operations can be modeled, even with operations, while large ship ports are an opportunity for modeling but lacks much in the way of operation.
I have boxcars from the PH&D and the Ann Arbor, and I also have a carfloat and carfloat terminal area. That was my choice, but it was a personal one. I haven’t regretted it.
