Detachable Section Track Alignment
I’m going to be building a detachable loop on my small N Scale layout. What are the experiences of others in aligning track reliably and securing the detachable section? I would imagine it would be smart to run track power leads to the detachable section. Other thoughts on how I might do this?
Eric
See the comments in this thread:
http://cs.trains.com/forums/1215860/ShowPost.aspx
since it covers what is essentially the same question.
Cheers,
Mark.
That other thread went in about fifteen different directions.
Here’s what I will tell you and I am going to build: Think removable leaf table.
Alignment: Use table pins like these: http://www.rockler.com/product.cfm?page=787&filter=32334
Holding it tight: use a locking mechanism like this: http://www.rockler.com/product.cfm?page=777&filter=21585
Keeping it level: use a drop-leaf support like this: http://www.rockler.com/product.cfm?page=2319&filter=30006
For connecting the power, use the power cables from the inside of an old PC.
I would construct the removable section, pin registered and securely latched.
THEN lay the track across the joint, securely fastened both vertically and horizontally.
THEN cut the track at the joint.
A simple dual banana plug to connect the power leads. You don’t need rail joiners if it is pin registered and secure.
I agree.
[swg]
Yep! That is how I do it.
That other thread specifically discussed attachment and alignment methods for cassettes, which are equally usable on a detachable layout section. That’s why I mentioned it.
That’s an unnecessarily complicated method you’re proposing. Why use table pins AND an alingment/locking mechanism? One is enough, but I would not use the wooden or plastic pins, the amount of clearance they would require to enable them to be easily pushed in and out means that they would not do a very precise job of alignment anyway. The brass pins would be a better bet, and they could be used to transfer track power as well, save you faffing around with power cables from a computer.
Mark.
Those locking mechanisms are designed to pull the two edges together tightly, but don’t protect against sliding or lateral movement.
I agree that wood or plastic pins would not be as good as metal ones, but I disagree with the idea of using them for track power… I think after a while any tarnish on the brass along with the fact there might develop some space arounf them might lead to unreliable conductivity.
