DH-163 WONT RESET ?
HI GUYS ,got a digitrax 163 that wont cooperate or reset (cv8=8) what I mean is tried reset on zephyr and decoderpro w/ pr3 but it does not reset decoder…I jacked it up when I tried to reprogram on decoder pro and I think I put the wrong decoder info in and now its stuck in ultra slow speed and wont let me change any thing , so I tried reset and that wont work ether.did all my home work digitrax site ,tonys save your decoder , only thing I haven’t tried is manual reset (pull the shell and hold the reset… any Ideas please …J.W.
oops ,its in a atlas rs3 ,ho,was working fine before triing to reprogram , (reprograming to get back to original speed setings cvs 3,4,2,5,6)
Do it on the main (Po on the Zephyr). Set CV8=8. Then either turn off track power or remove the loco from the track, then put it back on. Should now be address 03 with momentum and other cvs cleared.
thanks Randy,but no good, it just don’t want to reset ,it clicks,it blinks, but it don’t reset,I do have another 163 decoder to put in it ,but this one is only a couple weeks old. I cant believe it could be fryd it still works just cant reprogram ? J.W.
Are you sure that’s a Digitrax decoder? If it’s an Atlas/Lenz you need to write a 33 to CV8 to reset. Tryt it anyway. If that’s the wrong value, it just won’t take.
Clicks and blinks? Doesn’t sound like a Digitrax decoder (although blinking headlight means there is a short in the motor output). Maybe a wire came loose or got pinched in the shell? The way the older Atlas motor leads were, they used strips of bare copper, not wires, and the one that loops around from the bottom of the motor could easily touch something, which is why when I converted one of those I cut the strip off short and soldered a piece of wire to it.
yes guys Im sure its a digitrax dh163d ,hard wired not board replacement.(orginal light board removed) …well I call em clicks its the noise the unit makes as the motor spins during decoder read & headlight winks during decoder wright . and I was careful about the copper piece coming up from bottom of motor ,like I said ,was working fine, it went bad as I was trying to fine tune the speed matching to its sister unit that has a soundtraxx tsunami board in it so I was playing with the cvs 2,3,4,5,6 IR . decided to take it back to the computer and reload the original setting I had saved… but I think I loaded the file for the tsunami in to it bye mistake .it was at that point it was stuck in a slow speed and would not let me change settings or reset…cv 3&4 are set at 20 & 16 (the settings I have for the tsunami) they were suppose to be in the 5-6 range . any how I well pull the shell and have a look after church. thanks again for your help and patience with me …ps I m trying to have a set of rs-3s mud together but only one with sounds (cheap skate) and didnt realize, all motor decoders are not created equil…J.W.
Place the unit on a small section of track and use Ops Mode to programme CV8 with a value of 8 via the active address “00”. Then try it again, same thing, this time using Paged Mode. If your unit does not automatically cut track power when doing an address change in Paged Mode, do it manually, then restore power. Try Address “03” and see if it works.
-Crandell
thanks to all,tryed other ideas after church to no good outcome so I stuck in a new dh-163 I had for another project and all is good . not sure what to do about the stuck decoder, could not find any sign of problem or short in wireing except one small pin hole in the blue shrink wrap on decoder … well thanks to all J,W.
if going to church didn’t help? i suggest you send it back to digitrax for repair / replacement.
