I have installed DH123AT decoder in the HO Bachmann Shay loco. No problems there, I used 8-pin harness for the decoder.
But, as I run it, I noticed that decoder works in a strange manner. When I turn the control knob to FORW or REVERSE, loco starts a bit fast, like a little power surge is applied to the motor, and than goes smoothly through whole speed range, and also deccelerates with no surges. It seams the problem is only in the moment between idle and go.
I hope you will understand what is my problem. Anybody has some idea?
Does it do this only when you go from forward to reverse? If so, that’s being caused by slack in the gears. The motor turns with little or no resistance against ituntil the slack is taken up then it will hitch a little bit.
You may have CV 2, Start Volts, set too high. Start with it on 0.
CV 3, Start Momentum, may need adjusting. A higher value will result in slower startup.
Some decoders don’t function well on DCC if CV 29 is set to allow dual mode operation. Turn off DC operation by programming CV 29 with a value of 34 and see if that helps.
