Most (if not all) the engineman control lighting panels I’ve looked at have a separate switch for front and rear number lights; front and rear classification lights, walkway lights and engine room lights.
Some Alcos had individual lamps (except on the PRR) for each color of class light so a separate switch would select those, EMD used a lever-moundted device to place colored “roundels” in front of the single lamp, accessed from inside of the nose on E and F units or with a small lever outside on hood units.
You can access many locomotive operators manuals here:
Displaying the class lights on the model may be fun but it’s rarely done in a prototypically correct manner. If the class lights are needed, they would always be supplemented by a pair of flags, either white or green to match the lights. In the smaller scales realistic yet removable flags are nearly impossible to achieve.
I’ve seen numerous photos from the 70s and 80s of extra trains with class lights but no flags. I’ve also seen flags without the lights lit. A bit of wire and a bit of brass makes a workable flag in HO scale, I know a number of peope who use them.
That would depend on the operating rules of the specific railroad. Many of the rulebooks I have read specify “flags by-day; lamps by-night” and others the lamps supplement the flags at night.
See “Note to rule 20 and 21” at page bottom. New York Central, 1937.
The NKP actually fitted some of their Berkshires with sheet-metal “flags”. On some railroads, depending on the operating rules, every train is an extra but displaying flags or lights has been dispensed with in later years.
I happened to catch the Champion back in 1972 leaving St. Petersburg displaying flags for a section following!
The 1967 edition of the “Consolidate Code of Operating Rules” says, on page 33,
"CLASSIFICATION LIGHTS
All sections except the last must display two green lights on the front of the engine.
Unless otherwise provided, extra trains must display two white lights on the front of the engine."
And in the 1986 General Code, the successor to the CCOR, the use of class lights or flags isn’t mentioned at all, and the section on train orders no longer lists a form of train order for sections. I suspect the requirement of class lights for extras was dropped because of radios. The 1986 GCOR is the last edition authorizing the use of train orders, and it also lists DTC and TWC.
Very true, yet the converse is also somewhat true. The class lights on a bright sunny day are not going to be particularly obvious, especially when the train is passing at speed. That could be disastrous for a scheduled train running in sections. Canadian operating rules required whistle signals to be exchanged between trains when carrying green to make sure. Assuming that “Extra” freight was the scheduled freight you had to clear for was not going to result in a happy outcome either.
American rules did too. If the signal wasn’t answered by the train(s) being met or passed, the train displaying signals for a following section was supposed to stop and ascertain the cause.
