I was running a 2 loco consist using WiThrottle and with a MTH CW40-9 and BLI SD40-2. I saw that the MTH was struggling becuase the SD40-2 was holding her back. It seems my SD40-2 (and BLI SD9) ran a lot slower than all of my others so I started comparing them, side by side. From slowest to fastest right out of the box (of the ones I’ve dealt with so far) are BLI (SD40-2 & SD9), Atlas (GP38-2), MTH (CW40-9) and Athearn Genesis SD60E (9-1-1, First Responder). The Athearn is a fireball unless you toggle the ‘half speed’ button and its still the fastest even so. I’ve played around with CV3,4,5&6 in the BLI’s and the Athearn with little noticible change.
Can anyone suggest something to get some sort of speed matching?
Just like Ford, Dodge, Chevy, Toyota, Honda, etc., they all run different. You need to get out your manuals and work on CV 66 (Forward Trim) and CV 95 (Reverse Trim)
Those CVs ONLY apply if you use a 28 step speed table.
Not all the decoders support all 3 CVs from CV2-6-5. Which is hugely unfortunate, to the point where I no longer use any decoders that don’t.
But there are some things that apply, even when these CVs are supported. First, with CV2 set as low as it will go (usually 0, a few only allow down to 1), that is as slow as the loco can go. So to match then, you have to speed up the slower ones - the one that runs the fastest on step 1 is your benchmark, if CV2 is already 0, it can;t start any slower. So the slower ones need increasing values in CV2 so they match at the start. At the top end, with CV5 at the default, at full throttle, the SLOWEST unit is the benchmark. By adjusting CV5 on the others, you can reduce their full throttle speed to match that of the other. This is probably all you really need to do, but for those that support CV6, you can do the same with half throttle, only in this case you can make ANY of the locos the benchmark and match to it since you can either speed up or slow down the half throttle speed by adjusting CV6 to some value between CV2 and CV5.
Close, so one doesn’t drag another around, is close enough. There is no need to make them so closely matched that you can run 5 laps of the layout and the distance between two doesn’t change by so much as a fraction of an inch.
Question, with the MTH in the mix, would it require some type of program from MTH to change CV’s. I’m not even sure if MTH calls them CV’s. [*-)] I think they call it DCS ?
DCS is the system but I believe MTH still refers to the programming variables as CVs.
Dave,
Even locomotives from the same manufacture can vary in speed. And this can be contingent on a number of things: gear ration, linkage (steam), motor, lubrication, etc. The key is to speed-match to the lowest common denominator.
The easiest way to accomplish that is to adjust CV 2 (VStart) & CV 5 (VMax). Some decoders also allow for CV 6 (VMid). As long as you can match the top and bottom speeds, as Randy suggested, you should be just fine.
I’ve tried playing with CV values in 5&6 on the Athearn with no change. I slightlly modified the BLI’s which sped them up a LITTLE. I’m waiting for my interface cable from my Mac to my MRC system and will be giving this a shot using thre JMRI software.
Depends on what type of decoder is in each engine. Each manufacturer does things a little differently. On some, if you’ve enabled speed curves, the ‘normal’ speed CVs (2,5,6) don’t work. Some support CV 5 but not CV 6. Also, not all CV values work the same. On some decoders, CV 6 can be 1 to 256, on some it only goes up to 64. Any number over 64 will just result in the same as 64 - full speed.
As Randy says, you can’t use a CV to make an engine go faster than it’s top speed. If engine A is faster than engine B, you have to slow down engine A. You can’t speed up B.
Make sure you don;t have CV29 set to use a 28 step speed curve, or CV2-6-5 will be ignored. Otherwise, you should see some very different operation if you reset CV5 to the default vs setting CV5 to some smaller value, like 127 if the decoder goes to 255, or 32 if the decoder only goes to 64 (not sure which ones do that - ESU has a limit like that on the MOMENTUM CVs). 127 in CV5 as opposed to 0 or 255 should run at half the speed at full theottle (step 1 will not be affected). If the decoder supports all 3 values, then CV5 > CV6 > CV2, any other order and the decoder may do some really strange things - all that means is the top speed setting in CV5 has to be bigger than the mid speed setting in CV6 which has to be bigger than the start speed setting in CV2. Anything else doesn;t make sense anyway.
The Athearn with a Tsunami or a custom Tsunami won’t likely have CV6, a newer one with Tsunami 2 will.
Speed matching is a bit of a art in itself and everybody has their own method of doing it.
Personally, I do not speed match locomotives to other locomotives directly. I set the speed of a locomotive based on speed step. See chart below. Green highlighted speed steps are the ones i directly program. The lighter ones are interpolated (more on that below).
I have a set of rollers and Bachrus speedometer on my test track on my work bench. Each locomotive is placed on the roller ands I use JMRI to adjust the speed steps until they match the corresponding speed of the locomotive. This is done with Programming on the Main, which means the changes take place immediately, requiring to stopping the locomotive to change the CV.
I start at the highest speed steps and work my way down to the lowest. This gets the motors up to operating temp and gets the lubrication to what it needs to be during normal operation.
I would highly suggest you get all your locomotive maintanence in before doing this since it will really make the process much easier.
I don’t match all 28 steps (decoders run at 128 but everything is interpolated between the 28 steps. I use the check boxes in JMRI to indivdually set speed steps 1-7, 10, 14, 18, 22, 26 and 28. All other speed steps are linearly interpolated by JMRI and are close enough that I haven’t noticed.
I have done this with approximately 25+ locomotives now and they can all run in sync with each other. Manufacturers include athearn (BB,RTR and Genesis), Proto 2000 (Life like and Walthers), Atlas, Kato, and even a few brass models.
I have found that certain decoders (namely early digi
I had someone from the NCE list send me some test results from his club, showing how the NCE decoders don’t properly interpolate when running in 128 step mode - which I think is one factor why a lot of NCE users say there is no difference between using 28 step (which NCE systems default to) and 128 step mode.
Speed curves - the biggest thing DC users laugh at us DCC users over. I’ve just never seen the point. I toss any decoder that doesn;t support CV2-6-5 (CV6 is the one usually left out, sorry Tsunami) and using just those 3 I cna get even performance for ewach class of loco. Poor drive/poor implementation of BEMF (sorry, Digitrax) are also out, so my locos all start on step 1. CV5 is set so the top speed is something reasonable for the prototype - I may turn that down for my layout so that wide open the locos run not at their maximum prototype speed, but at the maximum speed that suits the compressed nature of my layout (or anyone elses, unless they build in an airplane hanger). CV6 comes in to tweak response over the new speed range, more powerful locos I can push it above the exact midpoint between CV2 and CV5, for faster acceleration off the line, for locos more suited to drag freights, I can set CV6 slightly below the mid point, so it takes longer for them to get moving.
In reality today - few of my locos have any settings other than CV2 to make sure they start on step 1, and most of the BEMF ones, at least ones with good BEMF, like TCS and ESU, don;t need CV2 raised for that to happen. An MU consist I use at club shows has a pair of P2K locos with TCS T1 decoders and an Atlas Trainmaster with QSI. I did nothing to them - they run fine together, yet if I put them on the track a few feet apart, eventually one will run into the other. But coupled to a train - they start up smoothly and pull the train for hours at a time. If I do something silly, like go from stop to full throttle instantly, then one drags the other two for a little while. But throttle up smo
I received †he MRC 1516 USB cable I canno† figure out how to conenct my Mac to the MRC Prodigy Advance2 command station. Is there a good forum where I can get help on †his and other issues I will have with JMRI going forward?
To be clear… yes I can plug in the USB connector and connect the other end to a ‘Cab’ jack. PanelPro preferences, setting up the MRC connector only shows a ‘bluetooth’ port and no serial port.
You will need software, and I doubt MRC even considered having something written for the Mac OS.
Since JMRI supports MRC, go to their website (jmri.org) or just google “jmri mrc”.
For support, join the JMRI email list at Groups.io. Many of the developers hang out there, so when you run into problems, they can help.
Current version of JMRI is 4.14. Follow the instructions to install it, and be sure to install Java first (or check that it already installed and the correct version).
I totally agree with Randy on standardizing decoders. While I’m an NCE guy, I’m not particularly a big fan of their decoders. TCS has been my go-to decoder brand for a few years now and their motor-control is hard to beat. (Only ESU comes close.) Rarely do I have to tweak anything, as they generally roll along at speed step 001 at 1sMPH or < right out of the box. Makes any speed matching fairly easy; since all I need to do is match CV5 (VMax) to the top speed of the other locomotive - or vice versa.
The thing about MTH decoders that I haven’t seen anybody mention is that they don’t use your typical speed steps. With MTH locos each speed step equals one scale mph. Just keep that in mind when speed matching them. Don’t try to change the MTH loco, change the other ones to match it.
