Some years back I bought several Radio Shack digital audio modules (276-1326) to add some sound effects on various sections of my layout after reading (in another train magazine) about them. These are stand alone battery powered devices. I lengthened the playback switch leads so that they could be located on my control panel. Everything worked great with one exception…I don’t necessarily have to push the momentary contact switch to activate the module. The modules are occasionally activated by other sources. Activation occurs when I run the trains, use accessories, or even if I touch the track after walking on the carpet. I suspect that these modules are being activated by EMI and / or static discharges. They seem very sensitive. Again they are stand alone and not connected to anything else on the layout. The only thing I have tried so far is to change the playback wire leads to twisted pair thinking maybe that would help with any crosstalk or EMI. It didn’t help at all. Any of you electronic experts have any ideas? Can I add a filter somewhere, or a ground, or something to eliminate the annoying modules sounding off without pushing the playback button.
Thanks, Mike
