Digital Dynamics
When will they ever get there site finished?
Over on the other board, I’m not registered, I saw a posting about adding TMCC to an ABA set. I have a similar K-Line set, all three powered, with the TMCC in an A unit with a pain in the [censored] tether from A to B to A. The poster indicated that they used “AC/DC DLX Conversion kits” and I was hoping to find some info at their site but alas it is still under construction.
Anybody done this and what kind of project is it ?
Digital Dynamics is a one man show. Ed is doing it all himself. No one to helps him from what I understand. I wish Ed could take it to the next level, hire some help and give TAS a run for their money. Not that I don’t like TAS but we are all better off with two players in the market keeping prices down and more products coming to market.
Gary
Dougnotagrump,
Did you go here? Shows price and info when I did.
http://www.digitdynam.com/f_cc_boards.htm
Regards,
Roy
Your browser has to be JAVA capable and have it enabled to see everything on the page. I normally use Firefox and do not see the menu buttons on the left side unless I use IE.
Pete
Thanks for the info guys. I bookmarked the address you gave me Roy. Looks very promising but very hesitant to try this again after my Mikado CC upgrade experience. Might have to think about it for awhile or maybe try TAS since they will also do the installation for a nominal fee. Food for thought. [D)] [sigh]
I bought a Kline cruise control kit from Ed Bender - Digital Dynamics. It was not hard to install. Ed was very helpfull when I spoke to him both before I ordered the kit and also after I had a question.
My only complaint was with the Kline supplied installation instructions. The instructions should have a Note inserted for the new motor driver board prior to replacing the conectors. The location of the two pin receptacle is turned 180 degrees with the guide slot from the original motor driver board. I was in a hurry and just (tried) recconected in the same direction as I first removed wires.
The Kline Mikado runs very well with the cruise control kit installed.
