Digitrax ARI hookup question
I’m an old school DC control 40 year model RR’r changing to DCC with a new loop to loop build in my “retirement condo” and it isn’t clear to me if the power for the entire trackage within a reverse loop section (mainline and sidings) is routed solely through the AR-1.
One reverse loop of my layout (15’ x 16’ room) has a lot of mainline trackage including engine storage tracks (will be power selectable w/toggle sw’s) along with railcar sidings and a 5 track yard. Since it’ll be just me operating the layout there won’t be more than two engines at most running at the same time within the large loop area. But this said, my concern is if all power to the reverse loop trackage is in fact routed entirely through the AR1 then the terminal wire size if less than #14 may effect voltage loss and engine draw current at the extremes of the loop given how finicky DDC feeder wire length is from everything I read.
My layout is a little larger than yours but what I did is run a separate bus for the reverse loop that is fed throught the AR1. The bus is 14 ga and will handle all the locos you have. Just make sure you label the bus as being for the reverse loop.
-Bob
Thanks for the reply Bob. So, just to confirm: The power for all the trackage wthin the reverse loop IS fed from the output terminals of the AR1?
Yes. I have about the same situation.
Thanks again for the confirmation…I’m good to go now. Just wish my old body was as nimble as it was when I was 40 crawling around under the benchwork installing and wiring plus-30 switch machines like I have ahead of me now. Getting down on the crawler isn’t the problem…it’s trying to get upright after a session of head bumping and swearing made worse having to contend with bifocals…[(-D]
As others have indicated, the AR-1 has the capacity to route power to quite a bit of track work within a reversing section. The input side of the AR-1 is fed power from the bus wires. The output side of the AR-1 routes power to all of the feeders inside of the reversing section.
Let me ask you a question about your layout from the comments you initially made. You express concern about the amount of trackage that is part of the reversing section. Are you sure that the reversing section needs to be as large as you seem to indicate?
Can you provide a diagram that we can look at to see if it might be feasible, or practical, to reduce the size of the reversing section while keeping with your overall track plan?
You mention how “finicky DDC feeder wire length is” in your post. How long are your feeder wires and what gauge are they? I have a fairly large layout with four AR-1 units. I use 14 gauge bus wire and only one set of main bus wires, no sub bus wires. My feeder wires are 22 gauge, and some of the run lengths are fairly long. But, I use very few feeder wires within each reversing section. How many sets of feeder wires are you using?
Lastly, regarding your ability to get around comfortably under the layout, a lot of us share your concerns and physical limitations. How high is your layout, and how tall are you? My layout is 36 inches high, a
Voltage loss is a result of wire size and length. The small contact area at the AR1 is only a short distance, 16 ga wire will fit in the terminals. Just solder or use a terminal strip to connect a short piece of 16 or 18 ga wire to your bus wires. Voltage drop across this short distance will be negligible.
The traces on the circuit boards are very small but do not cause significat voltage drop. That’s because they are short.
Martin Myers
[quote user=“richhotrain”]
Hi Over50,
I wasn’t suggesting that you make your layout smaller.
What I was asking was whether you were certain that you needed to wire so much of it as a reversing section.
Since you are concerned about the number and length of the feeder wires, it raises the question about whether the reversing section could be shorter and, as a result, the main section would be longer.
But, no intent to remove even one small section of the layout.
Sorry if you misunderstood that.
This is how I start my reverse loop bus, a simple terminal strip, which is in turn fed from the output from the AR1. That is all you need.
-Bob
Appreciate the visual follow up. [Y]
Sorry I didn’t have a more recent photo with all the wires in place, as this only shows the Reverse Loop bus wires.
-Bob
Bob,
Can you explain that barrier strip wiring in a little more detail.
Where are those wires coming from and where are they going to?
And where are the jumpers?
Rich,
The red and black wires are 14 ga bus wires that run the full length of my reverse loop section on the layout (approx. 15 feet long) from the terminal strip. In the photo attached (finally found one of the ARI) the AR1 is in the enclosure box and the wires coming in (right side) are from the main bus. The wires coming out (left side) go to the terminal strip in the previous photo. The reverse loop bus has feeders to all the track within the reverse loop. I use 22 ga wire for the feeders and connect them to the bus (14 ga) with 3M suitcase connectors (one is visible to the right in the photo of the AR1). I also use around a 24 ga solid wire soldered to the track and then soldered to the 22 ga stranded feeder wires. I do this at the bench and allow about 3-6" of solid wire (I put a right angle bend at the end and flattened it so it can be soldered to the rail flange with minimal size) soldered to the feeder and covered with shrink tube. This whole feeder wire assembly makes installation go quickly. Hope this explains everything.
-Bob
Bob…It wouldn’t have occured to me to put the AR1 in an enclosure as you have. I just figured you screwed the bare ARI in place on the bench work support near the point of the reverse loop turnout and wire to it. And the additional labeling sure makes for an organized appearance. Nice Job!
If possible I would really appreciate photos of how you laid out and mounted your DCC system components and in particular how you turn your layout power on and off. I’ve seen photos where the Digitrax DB150, etc., was located behind a hinged fascia panel door and others where the DCC system components are on a shelf under the layout which means crawling to access it …which I definitely won’t be doing…
Bob, what confused me was in your first phot earlier in this thread, you only showed two wires, a red and a black.
Sorry about any confusion, it really isn’t hard to get confused with DCC sometimes. As for my layout power on and off, I use a standard toggle wall switch like in you house wiring. This turns off a power strip which has the Digitrax Zephyr, power supply for my turnouts, power to the turntable motor and a few other small power supplies. I wanted to make sure everything was off when I left the room. these photos show the main control areas on my layout. The power switch is in the first photo to the right of the Zephyr and the other photos show the yard panel and the turntable panel. As you can see I like things to be labeled and organized (not the rest of the room; that is a disaster!). My facia is permanantly attached to the layout and has about 5 UP-5 plug-in panels around the layout as well as several other turnout control panels with diagrams of the track in that area. I also have some push buttons for sound modules in some of those panels. Hope this helps a little more.
-Bob
Thanks for the photos! Neat idea to use a standard wall light switch to power on/off your layout. I see you’re using the Digitrax Zephyr vs the Super Empire Builder with the DB-150 command station which is what I’d settled on.
Being new to DCC from what I read I didn’t think the 3 amp capacity of the Zephyr would be enough (vs the 5 amp for Super Empire) when you factor in engine sound, lighting, etc. But from what I can see (and as you mentioned) your layout occupies a larger space than my 15’x16’ footer so obviously it’s sufficient for your needs. Will have to rethink the Super Empire Builder…and for sure the more expensive option.
By the way, at the current state of my new build the top of the large loop area has become the central “put it there” location for tools, yet-to-be installed switch machines, etc., which also qualifies my layout a disaster area.
Also noticed the windows in your layout room which for you wasn’t a factor in your layout height. Unfortunately in my case it is, where my layout is in the basement and I had to keep the max height even with the window sill for egress by building code. As such my “crawl space” is 34 inches which translates into needing a mechanics crawler for all of the under layout work. 35 years ago crawling around on my hands and knees wasn’t a problem - AND - I didn’t need bifocals to see what I was doing. But at 73 suffice to say it’s a lot tougher just getting down on the crawler and back up … and for a casual observer a humorous sight to watch!
I will be 72 in 4 months and know what it is to crawl under and then try to get up again. My layout is 55" on the upper level and about 49" on the lower. The bad part is the two duck unders. I finally built a handrail on each side at about 20" off the floor, which gives me something to lean on while going under. It works quite well; now I need one on the other duckunder.
As far as the 3 amps vs 5 amps; I have about 15 sound DCC locos and haven’t had more than 4 running at one time but they don’t have any issues. You may want to look at the cost of the Zephyr plus the DT402D throttle and the UR92. They may cost more than a higher end system to start with. Just a thought.
-Bob
