Hi, Folks…
I wondered just how important is it to ground my 3 boosters to each other AND is this ground wire also supposed to be grounded to the household ground circuit ?
Everything I read, even in the Digitrax manual says “we suggest” this or we recommend that … don’t they know for sure? The manual is a bit ambiguous at times, to say the least.
Alan gartner “recommends” grounding and I guess I’m also supposed to CUT the #2 and #5 wires in the Loconet cable between the boosters… is it possible to have too much of a ground?
What would be the advantage to running the “heavy” ground wire between boosters?
Thanks, ED
