The locking tab broke off the plug/jack on my Digitrax UT4 throttle. What is the best way to replace it? The duct tape is too messy and makes changing locos awkward!
-Bob
-Bob
It’s an RJ12 connecter. You need and RJ12 connecter and the crimping tool to replace it. The tool has a wire cutter/stripper and crimper on it. The big box stores sell these. Digitrax has a kit with a 50’ length of wire, RJ12 ends and the tool.This is for making the loconet cables for joining the UP and UR panels together. Joe
thanks Joe, I will check with my local bigbox guys first.
-Bob
I ordered a Klein kit; stripper/crimping tool with a bunch of connectors on Amazon ($33 incl shipping). Home Depot had the tool ($30) but no connectors.
-Bob
Make sure to orintate the plug the correct way when replacing it. Joe
It’s good practice to orient the plug, but loconet cable pin out is “mirrored” so the 6 wires are A-B-C-C-B-A and so it does not matter.
NP.
Thanks guys.
-Bob
For a throttle - no. For other things, particularly additional boosters and BDL-168’s, it DOES matter, since two of the wires are the railsync lines and if they connect backwards to a booster, it will produce a DCC signal reversed from that of the upstream booster - Rail A will be Rail B and vice-versa. Safest to just always put the cables together the proper way.
Randy,
I had planned to put the new connector back on in the same orientation that it is now.
-Bob
