Digitrax DB150 shut down issues
But JMRI with the DB150 WILL save the values you set decoder CVs to. You just can’t read back what’s already there. But once you program a loco, what’s in JMRI IS what’s there, for future reference.
Randy, I am aware of that, but thank you. Having this many locomotives already programmed and not being able to see what they are set to because the DB150 never sends that info in the first place is an issue that I’m resolving.
Just wanted to give you all an update. I got the DCS200 and the DB150 set up with the PS2012. Everything works flawlessly. Nothing over heats. Most importantly, nothing shuts down.
In the process I even solved a over heating issue I had with a micro Tsunami in my H8, I put a huge heat sink in with it!! So I get to run that now too! [tup]
Thank you all for your help!
