Digitrax DH163D - Is it possibe to adjust dimming level?
Using Rule 17 dimming, the headlights are too dim. Is it possible to adjust like the TCS decoders? Can’t find any info on this.
Thx
Here’s a link to the Digitrax programming manual. It should have what you want.
Looks like the section you want starts on page 39
Good Luck
http://www.digitrax.com/ftp/decodermanual.pdf
That actually was the first place I checked and although I’ve got F0F programmed correctly I did not notice any mention of adjustable dimming.
Look at section 6.10.2, CV62. This is where you can adjust the lamp keep-alive voltage. This is how much power is supplied when the effect is ‘off’ or ‘dim’. The Digitrax decoders aren’t as asjustable as TCS, but you can change it.
Cool Beans,
Thanks - Bruce
I don’t think CV62 affects the dim level(if it does, I can’t not see any difference). It is for lighting effects that turn on and off, such as flashing ditch lights and FRED lights, not for the dimming of the headlights.
