i need help with the wiring of a tortoise slow motion switch machine to the ds64 as a crossing gate and also the proper way to wire the flashing lights. ive been reading the digitrax directions numerous times and i cant make sense of it.
The DS 64 does not control crossing gates or flashing lights. For that, you need a Logic Rail Technologies Grade Crossing Pro or similar circuit board. The DS 64 only controls switch machines.
You can purchase a Grade Crossing Pro from http://www.logicrailtech.com
That’s not true. The DS-64 can be configured to flash the lights and to use a Tortoise to control a gate. You do need detection to tell it when unless you want to control them from the throttle.
